Performance and Tuning Discussion forum for various performance tuning techniques and questions
anyone ever run the N-75 & a Boost controller in parallel
Old Jul 19, 2002 | 04:05 PM
CharlieGSanD's Avatar
Senior Member
Default anyone ever run the N-75 & a Boost controller in parallel
im thiking of doing this to control my overboosting problem, but im not shure about how it might affect the N-75's adaptation to boost control....
anyone have any thoughts/input?
Old Jul 19, 2002 | 07:09 PM
Afrosquad's Avatar
Junior Member
Hmm, I've wondered about this same thing...
Old Jul 19, 2002 | 09:03 PM
WYSIWYG's Avatar
i dont think there will be any benefit there. in series, yes
Old Jul 19, 2002 | 09:51 PM
Senior Member
Default explain......
i was thinking about that, but i dont think it would work
Old Jul 20, 2002 | 05:36 PM
Olympic Pace car's Avatar
New Member
Default Ever think it might be the wastegate??
it might be boost creep, but in a real bad form. I might try to port the wastegate or go external if you are experienceing bad creap. many Int. WG's suffer from it because it cant redirect enough flow out, so you are over boosting, its a common problem with internal wastegates.
search online about overboosting, boost creep
Old Jul 20, 2002 | 08:31 PM
Senior Member
Default if i have the Boost controller hooked up there are no boost control issues
but the B/C operates like a light switch, making the car difficult to drive th car slowly. the N-75 will feather the boost @ low RPM/load situations, increasing drivability...
i just want the best of both worlds
Old Jul 21, 2002 | 01:03 PM
New Member
Default its called your right foot =P
i dunno man, big turbo and good boost controller, thats what you get snappy lag, nothing nothing BAM!!! Am not familiar with the blitz unit, but was fairly positive you can make the boost more linear with the EBC's
i think the blitz uses an automatice and manual mode of operation. I would try adn play wiht some of the manual settings and see if that will help your 'problem' (id call it a blessing persoanlly)
Old Jul 22, 2002 | 06:41 PM
SKS's Avatar
SKS
Junior Member
Default What boost controller are you using? My Greddy Profec B has
a high and a low setting and those are easily adjusted with dials.
 Michael S. Palmer
Old Jul 22, 2002 | 07:53 PM
WYSIWYG's Avatar
Default it wont work in parallel in the sense that the N75 will be supplying air pressure as the software
requires - that will take you back to normal boost
Old Jul 22, 2002 | 10:08 PM
Senior Member
but the air pressure opens the W/G causing less boost
