AWE KO4
I always recommend replacing that oil line, especially if the car has the old style heat shield. Also replacing the heat shield if it's the old style too!
Consider the age & condition of your clutch too, as once you do the turbo kit, the clutch may be on it's way out once you put that power to it.
Don't forget to prime the oil in the turbo too. Pull the fuel pump fuse, and crank it a few times before you actually start the engine. That'll put oil through the system. ;-)
