Performance and Tuning Discussion forum for various performance tuning techniques and questions
Camber woes!
Old Oct 13, 2003 | 05:49 AM
Bryans12v's Avatar
Default Camber woes!
Put my car on the alignment machine at work and discovered why im tearing up my driver side tire on the inside. My camber is so far into the negative that it cant be fixed.
Dont ask me why theres no camber adjustment on these cars, its rediculous. The only way to adjust it is by shifting the subframe to even them out as much as possible, which is completely stupid.
So I pull up the table of measurements and the driver side front is FAR into the red, about 1.56 degrees negative while the passenger side is only about -1.10, so I loosen up the subframe and even them out to still keep me in the red on both sides now. From here theres not much more I can do.
I know the problem lies on the driver side due to an accident a while back but I paid top dollar to get the frame straight. I guess you sometimes dont get what you pay for.
Leaves me with not much I can do. Is a camber adjusment kit my only source of a solution, such as the CPP upper arm kit from AWE? I really dont think those links are worth the $700 they are going for. I just spent well over a $1000 on all new control arms, tie-rod end, sway bar links and everything else to get my car at one with the road. I guess being that I just put all new arms in stiffened everything up so now the problem is really showing.., its bad.
This really sucks...
Any advice would be greatly appreciated..
Old Oct 13, 2003 | 06:08 AM
Angry Alex's Avatar
Default a lot of places sell the CPP links you're looking for...
they just might do the trick.
Old Oct 13, 2003 | 06:35 AM
®ob's Avatar
Default 1.5 isnt bad really...
that's what I've run for quite a while.
Just make sure to rotate tires enough and it'll be a non-issue IMHO. By the time you notice excessive wear on the inner edge, it'll be time for tire replacement anyway.
Old Oct 13, 2003 | 09:01 AM
Bryans12v's Avatar
Default I know but them damn things are expensive!!
700 bucks is a little rediculous, isnt it?
Old Oct 13, 2003 | 09:04 AM
Bryans12v's Avatar
Default I know its not *that* bad but...
My car is a daily driver kind of car, not too much of a performing vehicle, you know?
Having to rotate the tires more often than I should is something im not looking foward to doing. Being that Audi's spec is -.25, being this far into the red seems bad to me. I would like to keep it at least (-.50 - -.75). To me, this would be more optimal.
Old Oct 13, 2003 | 09:16 AM
VAP's Avatar
VAP
Default you can source a homemade or pieced-together assembly...
find some 3/4" 7075 aluminum hex stock and have it bored and threaded at each end (L/R threads). Then find a couple Heim joints with the appropriate size ball center bores. It's really an easy task for a machine shop long as you can give them dimensions.
I could easily make these for about $70 per unit, parts & labor, and I even have the hex stock sitting around, but my plates a little full right now.
Old Oct 13, 2003 | 09:21 AM
Yippers®'s Avatar
Member
Default FWIW. WYSIWYG ran a camber adjustment system that was quite a bit cheaper than the CPP links. Maybe
shoot him an email and ask who's they were. My memory is an OZ outfit makes them ..
Also, you could always raise the car a little ..
Old Oct 13, 2003 | 10:02 AM
®ob's Avatar
I daily drive my car...
 Michael S. Palmer
Old Oct 13, 2003 | 11:25 AM
[ej257]'s Avatar
Member
Default He's got non-sport, and a solid 10" of wheel gap :)
And he's about to lower the car as well....
Old Oct 13, 2003 | 12:06 PM
Phil type 951's Avatar
Default those # dont sound bad @ all...... for your needs go with the
k-mac kit @ about 1/4 the cost. also good on a street car unlike the cpp option
