Performance and Tuning Discussion forum for various performance tuning techniques and questions
Cams,... (solid-lifter cams conversion)
Old Mar 17, 2002 | 02:50 AM
Audi R4R's Avatar
Junior Member
Default Cams,... (solid-lifter cams conversion)
Anyone with a turbo audi (A4 1.8T/S4/TT/RS4/RS6) that has bought and installed a solid lifter cams conversion? If so, what brand, cost, and any comments would be appreciated,... =)
And what did you do about the tachometer? Aftermarket? Moded the OEM one on the gauge cluster? Just curious!
Old Mar 17, 2002 | 07:43 AM
CMH's Avatar
CMH
Senior Member
I will be doing the solid lifters and a race cam soon.
Old Mar 17, 2002 | 11:11 AM
Audi R4R's Avatar
Junior Member
Default Could you tell me if there is a kit you're looking at?
Hey Mike! I already invested stupid money for my cams and internals, do you mind telling me what you plan on doing about the tachometer? And could you tell me more about the specs for the cams kit? Thanks.
Old Mar 17, 2002 | 11:21 AM
PanTTher's Avatar
Default Yes. No Kit available. Custom made. Good for racing purposes. Too Extreme for street use....
don't forget you'll also have to have new cams grounded from scratch and getting the profile right won't be easy and will most likely be expensive. The Hydraulic cam profile will not work with the mechanical tappets.
Old Mar 17, 2002 | 05:54 PM
PanTTher's Avatar
Default Just to clarify...by "Yes" I meant I thought about the mechanical conversion...
but it was too extreme for me.
Old Mar 17, 2002 | 09:41 PM
Audi R4R's Avatar
Junior Member
Default I bought a schrick kit conversion already
Hey there! I just bought the shrick solid-lifter cams conversion kit with ti valves, retainers, and valve springs. It was a pretty penny.
I was just curious what else was out there (if anything). Could you tell me what you meant when you said it was too "extreme" for you?
Old Mar 17, 2002 | 10:37 PM
PanTTher's Avatar
Default I should have guessed it. If anyone would of had it, it would of been them...
I looked into various options last year to get higher revs out of engine. I talked to Kent, Pipper, local gurus... but not Shrick. Dahlback quoted me $6K to do mechanical conversion on head ... (I thought he was out of his mind). I do know Hans Dahlback and Shrick have some sort of collaboration/partnership going. Anyway, it wasn't worth pursuing at these prices. One of the local head designers/guru wanted to design and build a set for the head (including cams) but I couldn't bring myself to take the risk. There were just to many design unknowns and I didn't think I had deep enough pockets to be able to cover unforeseen problems.
You should be able to get up to about 9.5 to 10 KRPM with a mechanical valve train if you change to a forged crankshaft, rods, wrist pins & pistons.
But I would love to see some pictures of the parts. You can e-mail me in private if you want to keep it off the forum.
Old Mar 17, 2002 | 11:01 PM
CMH's Avatar
CMH
Senior Member
That is exactly what I have planned for my 2.0 liter motor.
Old Mar 18, 2002 | 08:53 AM
PanTTher's Avatar
It turns out the kit is built to order only.
Old Mar 18, 2002 | 02:13 PM
xr4tic's Avatar
Default APR just announced they are working on cams for the 1.8T....
and it looks like a mechanical setup will be available. They didn't give a release date or price though.
