clutch issues need advice
After this day I started having issues with my clutch. It seems to hold power fine. But when engaging it from a stop, it slips a little and makes a screetching sounding that sounds similar to tires chirping. I can usually avoid this is I engage it right at 800 RPM, but then the car crawls away from a stop and that sucks. Also there is a little bit of chatter to overcome driving this way. It doesn't slip on a hard shift or under heavy load in any gear. I'm assuming this noise is from slippage, but I could be wrong. Whatever it is, something isn't feeling "solid". It's not so undriveable, it's just annoying and embarrasing. So anyways, when I had it in the shop a few weeks ago for a wheel bearing replacement, the shop drove it and suspected an issue with the pressure plate. Does this make sense? I'm thinking if it is the pressure plate, it really makes no sense to just put a new one in. If I have to pay for the labor and parts, I might as well put in a whole new clutch eh? I guess I won't know until we pull it all apart. But I was just hoping to be able to take care of it as quickly as possible. I'm wondering if it could be a damaged flywheels somehow. Just thinking out loud. I guess the good in all this is I can have the shop get to my cat and put my test pipe in while they have the tranny out of the way.
It feels like you're going to have to take it apart to diagnose the problem either way. But then what? Other than fixing this problem, is it worth changing the clutch just to get a sprung disk rather than the unsprung one that you have? (Actually, is it possible that the noise is from vibrations that would otherwise be dampened by a sprung disk??)
Clutches. Bah! I'm happier with my clutch at the moment, but that's just because I have power steering and DV issues now.
Bad spirng on clutch same symptoms
Over heated PP or flywheel
Could be as simple as a quick resurface on the flywheel, or as bad as a flywheel/PP and clutch
Ganna have to tear it down and see
If you're going to change it, might as well have a little fun beforehand
After my clutch "incident" I was getting ready to tear it apart, but it started working again. I'm just going to beat on it until it starts slipping really bad, then surface the flywheel, and get a new disk. I'm curious if the pressure plate can be reused?
