Performance and Tuning Discussion forum for various performance tuning techniques and questions
Coilover Install
Old Jan 12, 2005 | 06:22 PM
Sleeper2.7's Avatar
Default Coilover Install
Hi All:
I have just removed the Struts from my 2.7T and I am ready to install H&R Coilovers. However the Bentley CD says the an axis through the upper spring mount mounting bolts should be about 11 degrees from an axis through the fork mounting holes at the bottom of the strut. Since I have no means of measuring this, I was wondering if any one has a method of setting this up. Otherwise I guess I will have to resort to a Trial and Error method untill it fits in correctly. Any help would be greatly appreciated. Thanks
Old Jan 12, 2005 | 06:30 PM
Audi2ptzero's Avatar
Elder Member
Cant you just use the stock struts to match this up?
Old Jan 12, 2005 | 06:33 PM
Sleeper2.7's Avatar
Default Re: Cant you just use the stock struts to match this up?
Well I had to dismantle the stock Struts in order in order to get components from them. So I really did not have anything the match up.
Old Jan 13, 2005 | 09:05 AM
Elder Member
Default Can you rotate the shock after you put it all together?
I am sure you can get it close by eye and then adjust it as you put it in.
RaselB5A4
Oct 8, 2013 07:01 PM
absolutcq20v
Aug 7, 2007 07:37 PM
Sleeper2.7
Jan 13, 2005 07:07 AM
donp
May 4, 2003 08:14 PM
brian1
Feb 13, 2003 10:57 AM
