compression test...
possible bad news... or an excuse for new bottom end~
compression test:
clyinder - psi - w/ oil (psi)
1 - 163 - 185
2 - 130 - 160
3 - 90 - 140
4 - 130 - 135
valves seem alright, but rings seem like they're leaking. I checked this today after finding a cracked spark plug (IK22) in cyl# 2 & 3. I'm going to RC engineering to get my injectors checked up. Any other inputs or tips? thanks~
Engine Mods: '01 A4 1.8tqm. PES T28 kit (w/ 390 injectors), Spp Zflow Fmic, EFK, UR pulley, HKS air filter, HKS EVC4, Milltek exhaust, EVO hi-flo cat, Iridium IK22, ECS adjustable FPR.
I was boosting roughly 20psi. a/f meter reads about .87 at richest point.
I had that problem once - I think that as kept cranking the engine - the cylinders got washed with gas...
I found it too coincidental that the #s went down as I tested them and realized I forgot to pull the fuel pump fuse. The results were fine after that... 185s all the way around.
This may not apply to you since you also did do it w/ oil and #3 seems lower than the rest. Anyway - just a thought...
