Crap, limp mode again
What other issues can cause limp mode? Probably a lot... I probably need to VAG it then narrow down the problems, but if anyone has ideas, PLMK.
Thanks,
FB
I replaced the vac line from the dv to the intake mani, from the front of the car under the intake manifold, and the short one on top. Does the vac line in the back have anything to do with boost? Any other vac lines to check?
Maybe a hose is bad somewhere as well...
I'll let the car finish cooling off and take a look later.
I want to just get every hose and every vac line replaced, lol.
Thanks,
FB
I'll see if it's still in limp mode today.
Actually, I thought of something else. I didn't have the right clamps at the store, not small enough. The vac line is smaller ID than stock, and fits pretty snug on the nipple. The clamp kind of goes "oval," so it may not be sealing properly. Dumb question: could it leak right at the nipple even if the hose fits snug? Should I not use the clamp at all so it seals better? I know, just get proper clamps...
Thanks,
FB
-Brent
I think it's the latest version, but I'll check. Thanks for the heads up.
BTW, does limp mode just go away after a little while, even if you don't turn the car off? I got it yesterday, turned car off at a light, and it was still there when I turned car back on. I got limp mode on the way to work, but after driving for awhile it seemed to be boosting again...
I guess I answered my own question, but can someone confirm this?
Take care,
FB
If your CEL *IS* coming on it might just be your BPV sticking open and causing the car to run super rich, misfire and die but I don't think that would cause a limp mode...
How about EPC light? is that thing coming on? If that's the case then it could possibly be your MAF reading out of whack and screwing up the torque calculations and sending you to limp.
Some limp codes won't go away with a key off/key on, I don't know why this is. They have to be cleared out of the ECU fault codes *OR* the problem has to go away putting the fault code in intermittent status and giving you your power back.
-Brent
No CEL no EPC light. Actually, I'm not sure what the EPC light it, but I'm not getting any lights. =)
It seems like I get the problem if I try to floor it from low rpm, like <2500 rpm. It hits 3000 rpm and I'll boost, but then the next time I try to get boost, there is none. I think this mode where I get no boost is limp mode, right? Then, after awhile, it will be back to normal. Strange, huh?
Restarting the car doesn't necessarily clear the state, but after driving a little more it seems to be back to normal...
Could my BPV orientation be wrong, like it's sticking then I get boost back when it 'lets go'? Again, it's a new rebuildable bailey, and I have the vac line in the obvious place, short hose that points "up" connects perpindicular to the vac line or on the "side" of the dv. The longer hose that hangs down from turbo goes into the "bottom" of the DV. As far as I can tell, this is correct.
Any ideas?
Thanks again, appreciate the feedback.
FB
