engine management for 5 cyl?
I always forget about Haltech, not sure why, its not like the product is bad (it isn't).
The big reason that I kept the distributor is that I can use standard replacement parts and the installation looks much neater than having to find a place for 5 ignition coils with associated wiring etc. Also the additional cost was not justified for the minimal likely gains.
As for restricting power, I work on race engines, many of which still use distributors, and I know the cylinder pressures I will generate in a N/A I5 will never appproach the limits of a well setup distributor system. BTW it is usually accepted that a distributor system with 1 coil is good for 8000 RPM on a 6 cylinder application. (Yes I did mean 6)
I think that reliability is also not an issue as the OE system has proven to be reliable for typically hundreds of thousands of kilometers in each application.
Please don't take offence, I am just trying to help you make a fully informed decision and my findings may not directly apply to you.
Neil
Just some food for thought.
it was on this page...<ul><li><a href="http://www.quattronut.org">http://www.quattronut.org</a</li></ul>
