Performance and Tuning Discussion forum for various performance tuning techniques and questions
ESP light problem
Old Feb 10, 2007 | 06:43 AM
mikeg330's Avatar
Default ESP light problem
My ESP light comes on even if there were no traction issues after driving for a few minutes. The only way to get it off is to restart my car. Also my rear light and center brake light indicator also has been on.. I replaceed the bulbs....it is pretty cold in Chicago...maybe that has something to do with it all???????
Old Feb 10, 2007 | 05:37 PM
Ertman's Avatar
might want to post in the chassis specific forums (B5, B6 etc)
Old Feb 11, 2007 | 08:07 AM
WJM's Avatar
WJM
Tech Guru
likely your brake pedal sensor is malfunctioning . If you have a vag, check it out.
Old May 4, 2007 | 06:57 AM
ptempel's Avatar
Default Check your brake light switch
It's a common item to fail and it lit up my ASR light on my 2005 Passat wagon. I believe ESP uses the same brake ABS system to control wheel spin. What code do you get with a vag-com? It should point right to it (mine did). If this is the prob, then search vwvortex.com for a writeup on installing this switch.
Old May 22, 2007 | 12:58 PM
shady1power's Avatar
New Member
Default Re: ESP light problem
it the brake light switch
ajpow365
Q5/SQ5 MKI (8R) Discussion
Dec 14, 2020 01:19 PM
sooneratphilly
Apr 26, 2011 03:48 AM
mikeg330
Feb 9, 2007 11:58 PM
MaxHedrm
Sep 20, 2006 10:39 AM
