Performance and Tuning Discussion forum for various performance tuning techniques and questions
Fuel control
Old Nov 24, 2002 | 06:05 AM
johnAWD's Avatar
New Member
Default Fuel control
Has anyone installed an Apex-i S-AFC into and A4? If so, I'd like to discuss it with you.
Thanks.
Old Nov 24, 2002 | 09:04 AM
Audi2ptzero's Avatar
Elder Member
Search for Stephen(R4R) he has had one on both of his A4's.
Old Nov 24, 2002 | 10:49 AM
Lambo-Bully's Avatar
Default Yes, it can be done. I'll be doing mine with the new engine.
You'll need the rpm, throttle, Maf, power & ground signals right. Apexi super afc won't work on a dbw, since it can only manipulate one signal(MAF or MAP) by what I know. I'll post a thread when I do mine if you can wait until January
Old Nov 24, 2002 | 02:38 PM
johnAWD's Avatar
New Member
Default Re: Fuel control
Cool - I figured as much. Is there a pinout of the ECU/ECU harness online somewhere?
Thanks.
Old Nov 24, 2002 | 02:46 PM
cuatrokoop's Avatar
Default Re: Yes, it can be done. I'll be doing mine with the new engine.
Yeah, that pretty much sums it up. One of my roommates put an S-AFC in his 90q12v (he hasn't had time to tune it).
Gotta spend time with the Bentley wiring diagrams, and a DMM, to find the proper connections.
Old Nov 24, 2002 | 05:06 PM
I've already done my homework, as far as the wiring diagrams go. I'll just need to do the probing to check the signals prior to hook-up, and see which throttle signal I'll need to use. Audi's use two signals from the throttle, and they criss-cross so to say....I'm guessing I'll need the one that goes low to high?
Old Nov 24, 2002 | 06:10 PM
cuatrokoop's Avatar
I can't remember which signal we found worked best for the throttle position, but I do know that we used the cam position sensor for the RPM.
It took several hours of me trying to get at plugs under the hood with probes connected to the SAFC, and someone else working the "go" pedal and watching the SAFC display, before finding proper signals. Hopefully, it will be worth it when the engine is finished being built...
Old Nov 24, 2002 | 06:33 PM
johnAWD's Avatar
New Member
Default Great
If one of you guys who's been there & done it would do a writeup of the procedure, I'm sure it'd go far to help out your a4 brethren.
Is there an ECU pinout diagram out there? Anyone? Buehler?
 Michael S. Palmer
Old Nov 24, 2002 | 08:47 PM
AEGA4's Avatar
Junior Member
Does his car run fine with it on and not tuned?
Old Nov 25, 2002 | 06:36 AM
BLFaster's Avatar
New Member
Contact me off the list if you are interested in the pinout for the S-AFC
I have one installed on a 1995 Audi V-6 12V Hitachi ECU
