FWD Problem solved
It turned out that a bolt that holds a cross member to the subframe.. or something similar, sheared the welded nut off. The popped in a new hole, welded a new nut and fixed everything up just fine. $125.00 and the car runs great.
Befor you raise an eybrow at this, I will say my son curbed the car a year ago, and went through a complete left side half shaft,CV Joint, Upper and lower frame, strut, wheel, rotor, rear axel assembly bent and replaced, and then some.. so for this to happen even a year later with 3 auto crosses and a limrock park PDA Class) is a likely occurence.
Thanks again.
