Good technical question....
I installed a set of boxster brakes into my A4 using EVO MS' aluminum carrier brackets. However, the bolts that came with the kit - the ones that bolts the carrier to the hub - are too long (by about 2 or 3mm). So, I am forced to put a couple of aluminum washers to keep the bolts from bottoming out onto the rotors.
So, here is the question - Can I cut the bolts (steel) down about 2 or 3mm, without compromising the integrity of the bolt... and the bolt's ability to stay on the hub? I believe I can... but want to check with the people here first.
Thanks,
Cris
