Performance and Tuning Discussion forum for various performance tuning techniques and questions
Hard pipes?
Old Feb 6, 2003 | 01:36 PM
SameerP's Avatar
Default Hard pipes?
What are the advantages of hard pipes to replace rubber hosing? For instance:
1. IC to throttle body
2. turbo to IC
Seems the IC to throttle body hose is very convoluted, that can be made much cleaner and straight.
Disadvantages? Pricing seems pretty reasonable for these things
Cheers,
Sameer
Old Feb 6, 2003 | 02:27 PM
Audiboy's Avatar
Default rubber expands or contracts depending on how much boost or vacuum...
Interior volume changes, and that could cause momentary pressure drops, and then slight surging when excess pressure is built up by hoses returning to normal formation
Old Feb 6, 2003 | 02:37 PM
Audi2ptzero's Avatar
Elder Member
Default You need rubber lines from the turbo/IC and IC/throttle body
since the IC lines dont move and the motor does.
Old Feb 6, 2003 | 08:37 PM
WYSIWYG's Avatar
Default i'm with mike, you need some rubber to isolate the car from the engine
unless you want a front dts
silicon hoses are actually pretty hard especially the straight ones - you'll need a couple of hump hoses for some flex
Old Feb 6, 2003 | 11:13 PM
Elder Member
Default I would hate to see what happens when the
motor snaps a motor mount with all hard pipes in there. I did get to see a S4 break both motor mounts, cracked all the rubber lines to the IC and even put 2 large dents in the hood. This happened at Carlsbad after they put the new clutch in the night before. I bet that was a long flat bed ride all the way back to LA.
Old Feb 7, 2003 | 06:58 AM
WYSIWYG's Avatar
pffft i saw an S4 in englishtown drag racing without a snubmount
Old Feb 7, 2003 | 09:14 AM
CharlieGSanD's Avatar
Senior Member
Default Check out SMOKINA4TURBO's setup.....
he has something similar to that
Old Feb 7, 2003 | 10:14 AM
SameerP's Avatar
btw how's the car running?
 Pouria Savadkouei
 Michael S. Palmer
Old Feb 7, 2003 | 01:10 PM
dspy's Avatar
how about using an exhaust flex joint?
Old Feb 8, 2003 | 03:58 AM
Typist Formerly Known as (skene)'s Avatar
LOL!!!! and it did 14 flat.
