Performance and Tuning Discussion forum for various performance tuning techniques and questions
Help me!!
Old Feb 10, 2003 | 03:35 PM
mrcj7's Avatar
New Member
Default Help me!!
I have recently bought a 1996 Audi A4, my first Audi. It has high miles(95,000) and there are some things needing some attention. The first thing is possibly the tranmission. At 40mph the car shutters until about 50. If I put it into neutral it doesn't shutter, ruling out tire imbalance. It is getting worse and I don't know if buying this audi was a mistake or not. Secondly, the passenger side floor is soaked. Any suggestions on where the AC drain hose is located? I am also in need of a climate control module(lights are out), instrument cluster(lights out), power lock motor(it locks but doesn't unlock, and a headlight switch. Are these things a common problem? If ANYONE has ANY advice on repairs of parts to purchase I would GREATLY APPRECIATE IT. THANKS!!!
Old Feb 10, 2003 | 09:43 PM
moribundman's Avatar
Default Holy crap!
I had a a very bad experience with Audi regarding the (manual) transmission.
My car developed a noisy 3rd gear at around 28,000 miles. Audi picked up most of the cost, but I got stuck with a $2,300 bill for the rest. They claimed a "chipped tooth" /damaged third and second gear (they tried blaming that on me! How could I have done that? The gears are in constant mesh!), and a bad main bearing. It took them all in all about 6 weeks to fix the transmission. First they couldn't get the part ("stuck in customs"), then they figured out they had to order a special tool they (authorized Audi dealer!) didn't have.
The first gear has been noisy since around 60,000 miles. The clutch cable is totally squeaky, too. I've got now over 120,000 on the clock and hope the tranny won't blow up. :-\
What I'm trying to say is, you can possibly go a very long time with a tranny that is noisy, but you say yours actually causes shaking...
About the leak:
Maybe your heater core is leaking? I think you may have to remove the whole dashboard to get to it.
The climate conmtrol unit:
I had the background illumination fail twice. There are little bulbs you can replace when you pull the unit. I hope the display still works?
The door locks:
You say you have a '96? Mine is a '96 and the central locking system is vacuum activated. I was lucky with this system. Later models have electric lock actuators, I believe.
Good luck!
Old Feb 11, 2003 | 12:18 AM
JAFO's Avatar
Default imho the shutter is more likily a half shaft problem....
what trans? fwd or quattro?
Old Feb 11, 2003 | 06:46 AM
MFZERO's Avatar
The climate conmtrol unit: check your fuses, mine burnt out and i had no lights or controls
Old Feb 15, 2003 | 06:17 PM
mrcj7's Avatar
New Member
Default Re: imho the shutter is more likily a half shaft problem....
FWD, auto
Prizemt
Texas Discussion
Aug 23, 2018 09:50 AM
idealdreams
A4 (B9 Platform) Discussion
24
Jun 18, 2018 11:14 AM
Guntor
Q7 MKII Discussion
Jan 7, 2017 09:01 AM
Audi.Enthusiast01
Jan 18, 2007 10:06 AM
mrcj7
Feb 11, 2003 07:52 AM
