Performance and Tuning Discussion forum for various performance tuning techniques and questions
Hydraulic fitting
Old Mar 11, 2003 | 01:18 AM
moribundman's Avatar
Default Hydraulic fitting
I need to replace a leaky hose that comes from the power steering reservoir and is at one end connected to a metal tube via a hydraulic fitting. I got the spare hose (without a new hydraulic fitting), but I'm not sure how the hydraulic fitting functions. How does it work, how does it come off, what do I have to do to replace the hose?
<img src="http://home.earthlink.net/~triphibious2/ps2.jpg">
Old Mar 11, 2003 | 06:56 AM
xr4tic's Avatar
Default You need to remove the whole line.....
and have someone put a new clamp on it. You have to have the right type of hose, you can't just go and buy some fuel/vacuum line from the local parts store and hope to clamp it on.
You're probably better off buying the whole line from the stealership.
Old Mar 11, 2003 | 11:26 AM
Default Sounds expensive
I actually have the correct spare hose, but it came without the hydraulic fitting.
Old Mar 11, 2003 | 02:04 PM
Yippers®'s Avatar
Member
Most NAPA stores will swedge fittings on hydrualic hoses. Might want to see if a local NAPA can help
Old Mar 11, 2003 | 02:16 PM
Default Okay, how do I remove the fitting?
Do I have to twist it off?
Old Mar 11, 2003 | 02:33 PM
xr4tic's Avatar
You need a new fitting, the old one isn't reusable.
Old Mar 11, 2003 | 05:15 PM
brian@avalonmotorsports's Avatar
Former Vendor
Default Re: Hydraulic fitting
The entire hose needs to be replaced. The line itself is not terribly expensive, and the installation is easy if done from the bottom. That line also acts as the p/s cooler, the hard line snakes around under the engine before meeting the pump. Collin is our installation / technical specialist, trained as a dealership technician, he has done the procedure before, and assures me it is no sweat. Call us if you need to, good luck!
Old Mar 11, 2003 | 07:31 PM
Okay thanks!
 Michael S. Palmer
Elliottv8
Mar 4, 2007 07:53 PM
Heed
9
May 7, 2003 08:28 PM
moribundman
Mar 11, 2003 06:52 AM
CGTCOMM86
May 30, 2002 02:22 AM
