I Found LEMMIWINKS program.
You could use this to lower your WOT fueling if you are too rich up top.
For instance:
You run mbc with larger injectors. Your part throttle fuel trims are good but your wot a/f is too rich. You could reduce the SEL which would reduce how much fuel you request @ WOT.
If your part throttle is too rich or lean you adjust primary fuel request to adjust this.
Hope it helps
If you dial in your part throttle to 0% trim on block 032 and your WOT is STILL rich then you can use the SEL scaling to bring down the WOT A/F without affecting part throttle trims!
BTW the increasing and decreasing load adjustments are only for intial throttle pedal changes and WILL NOT affect WOT A/F.
BTW read about your car in the European car. Nice Job
Thanks.
