intake questions please
I would greatly appreciate your honest answers, they have took me in the right direction before!!!
Here's a picture of the two injectors:
http://community.webshots.com/storage/1/v2/4/76/56/27647656FLGugtdkHt_ph.jpg
However problem is solved. I have found sources for the long stem nozzle injectors that flow to almost 400cc.
I have a question for you.
Where did you get the info about our FPR? From testing or you heard that from a tuner?
Assuming they're rising rate and increase rail pressure to 90psi at 12.5psi of boost, it's closing fuel return completely at that point am I correct? So the pump is the limiting factor at that point.
So an I correct to assume a 3bar and 4bar would have the same rail pressure under full boost since fuel return is closed. The only difference between them is at part throttle or idle operation or when manifold press is below 12.5psi.
plenty of air gets into that little chamber. after hard drives i'll pop the hood and the black tube is always cold to the touch. i'm not worried. i'm popping the stock airbox back in during summer tho. texass just gets WAY TOO HOT.
