Intercooler ideas? need input
why not put a cooling jacket around a custom alumninum(sp) intake tube. Fill the jacket with water and have a samll eletrical pump cycle it through into a small radiator at the front of the car, to cool water, then to a reserve tank. or use the radiator and have the water pump do the work ( i suggest water becasue the higher cooling rate (ie higher specific heat)). I mean while I'm at it why not place a jacket around the turbo, to reduce heat. I understand the turbo requires some heat but come on that glowing red turbo isn't exactly helping your intake temps. How about placing a jacket around the intake manifold.
Just throwing out ideas
Stock A4 Turbo
He talks very well to the advantages and disadvantages of air-air and air-water intercoolers, as well as touches upon more "esoteric" (e.g. > 100% efficiency) intercooling techniques.
Richard is right...you've re-invented the air-to-water IC.
Regards,
James R.
2001 A4 1.8TQMSXP (Turbo5 Stage III Brakes, AWE Stainless Steel Lines, Oettinger Pedal Set + Dead, Oettinger RE's 17x8, Yoko AVS Sports 225/45/R17, European Xenon Housings, Bailey BPV & RS4 Grill)
