K04 problems: graph of requested vs actual boost
Let me know if anyone has tried these and I will see if I can find some other options. But I think there are really just the 2 causes so....
> You mentioned that the spikes occur at lower rpms. I am running about
> 16psi using a BoostGraphic. What I see is that at lower rpms, the
> boost does *not* spike (at least not much), but at higher rpms, I get
> a serious (4-6psi) spike.
Does this occur when you first bring the boost up (i.e. you get on the
gas, and boost shoots to 19 psi and quickly goes back to 16), or does the
boost stay at 16 psi through the midrange and then start increasing at higher
rpms? If it stays constant then increases at high rpms, you do have boost
creep. Boost creep is caused by inadequate wastegate capacity. Once you
reduce backpressure enough (a downpipe/testpipe/free flow exhaust combo
will often do it), the stock wastegate becomes inadequate. To fix
it, you have a couple of options: 1. Increase wastegate capacity by
enlarging the internal wastegate opening or 2. increase exhaust backpressure.
Option 1 is the preferred choice since reducing backpressure as much
as possible is otherwise beneficial. Another possibility might be that the
boost graphic is malfunctioning and not working properly. A properly
functioning bleeder valve should not cause boost creep.
Keep in mind that all motor when you have a lot of mods still requires a lot of maint and care. It's not necessarily totally reliable. For example, lots of guys on Honda-Tech are reporting wear on Ti retainers, timing belts breaking, etc. Just be careful man! I had chosen all motor so my car would be reliable, but it wasn't meant to be...
With a fairly mild setup, you can have probably the best handling FWD car with good power (13s on street tires) and still be pretty reliable.
If you don't already, check out honda-tech.com. I'm a moderator for the DFH~Decal Free Hondas forum, even though I don't even have a Honda anymore. =)
Take care,
FB<ul><li><a href="http://www.honda-tech.com">Honda-tech - good technical/fun honda forum</a></li></ul>
BTW you cant just use a bleeder valve on a car that has a boost sensor and will throw codes and make the car run into limp mode.
You are playing 2 different games when it comes to your non dbw 98 and the 2001 car that has twice as many sensors.
I also have a 95 GST eclipse still running stock other then a new wastegate actuator from HRC and the car runs mid 14's.
