The latest pics.......
<a href="http://johnbaas.dyndns.org/2point0/plumbing_1.jpg" target="_blank"><img src="http://johnbaas.dyndns.org/2point0/plumbing_1_lo.jpg"></a>
You can see the flange a little better here, along with the BPV connections. I need to add a flex hose on the outlet pipe:
<a href="http://johnbaas.dyndns.org/2point0/plumbing_2.jpg" target="_blank"><img src="http://johnbaas.dyndns.org/2point0/plumbing_2_lo.jpg"></a>
The filter location. I think I may try to move the AC thingy (dryer/receiver maybe?) out of the way to make more room (probably when I put in a FMIC)
<a href="http://johnbaas.dyndns.org/2point0/plumbing_3.jpg" target="_blank"><img src="http://johnbaas.dyndns.org/2point0/plumbing_3_lo.jpg"></a>
Engine shot
<a href="http://johnbaas.dyndns.org/2point0/engine_done_1.jpg" target="_blank"><img src="http://johnbaas.dyndns.org/2point0/engine_done_1_lo.jpg"></a>
Closer shot of the crankcase breather and ignition module (POS) and my ugly homemade bracket
<a href="http://johnbaas.dyndns.org/2point0/engine_done_2.jpg" target="_blank"><img src="http://johnbaas.dyndns.org/2point0/engine_done_2_lo.jpg"></a>
You can kind of see the downpipe here. If you use an external wastegate, or a better output flange, it will be a straighter shot.
<a href="http://johnbaas.dyndns.org/2point0/engine_done_3.jpg" target="_blank"><img src="http://johnbaas.dyndns.org/2point0/engine_done_3_lo.jpg"></a>
<a href="http://johnbaas.dyndns.org/2point0/engine_done_4.jpg" target="_blank"><img src="http://johnbaas.dyndns.org/2point0/engine_done_4_lo.jpg"></a>
And, of course, the gauges to keep an eye on it all:
<a href="http://johnbaas.dyndns.org/2point0/gauges_8.jpg" target="_blank"><img src="http://johnbaas.dyndns.org/2point0/gauges_8_lo.jpg"></a>
And the turbo-timer for us lazy folks
<a href="http://johnbaas.dyndns.org/2point0/timer_5.jpg" target="_blank"><img src="http://johnbaas.dyndns.org/2point0/timer_5_lo.jpg"></a>
Here's a quick diagram I whipped up:
<img src="http://pictureposter.audiworld.com/12130/bpv_plumb.jpg">
Just find a spot where there's some room to run the hose, mark the pipes, and weld the tubes in.
I don't remember what the consensus was on the BPV orientation. I think I have it right on the drawing (and my car)
I don't think it really matters, one way will help it open faster (the way in the drawing), the other way will help keep it closed under boost.
Vishal
