Misfire prob
Have you checked the plugs that are in the car to see what they look like and what their gap settings are? I would also do a compression check on the motor. A loss in compression can cause the car to misfire at idle and run a little richer during boost. Another thing to check is you injectors, move them around and see if the issue moves. Same goes with your coil packs. The last thing I would look at is your maf, if the readings jump up and down for some reason this can cause the ecu to give too much fuel at set times which can cause your idle misfire issue.
