Performance and Tuning Discussion forum for various performance tuning techniques and questions
My intake set-up.
Old Apr 27, 2002 | 01:32 PM
Dead's Avatar
Elder Member
Default My intake set-up.
Seals against the hood. ABS plastic with metal heat shield on exhaust side.Seals against the front and rear cowels.Just need to finish new duct from OEM location.
<IMG SRC="http://pictureposter.audiworld.com/8297/scoop_lift.jpg">
<IMG SRC="http://pictureposter.audiworld.com/8297/scoop_day_close.jpg">
<IMG SRC="http://pictureposter.audiworld.com/8297/scoop_day1.jpg">
<IMG SRC="http://pictureposter.audiworld.com/8297/scoop_pipe.jpg">
<IMG SRC="http://pictureposter.audiworld.com/8297/scoop_pipe2.jpg">
<IMG SRC="http://pictureposter.audiworld.com/8297/new_intake_seal_hood.jpg">
<IMG SRC="http://pictureposter.audiworld.com/8297/new_intake_front.jpg">
<IMG SRC="http://pictureposter.audiworld.com/8297/new_intake_engine_side_3.jpg">
<IMG SRC="http://pictureposter.audiworld.com/8297/new_intake_engine_side2.jpg">
<IMG SRC="http://pictureposter.audiworld.com/8297/new_intake_engine_side.jpg">
<IMG SRC="http://pictureposter.audiworld.com/8297/jaime_scoop_biplane2.jpg">
An alternative way to duct the intake.
Old Apr 27, 2002 | 06:57 PM
Bryans12v's Avatar
Default Nice Job Dave....
Looks familiar
I did a little fab work w/ the stock airbox to come up with something similar. Did you have to relocate the horns as well...?
What I did was I went straight through with a 3" Y pipe that runs straight through to the wheel well as the Y bends off early up to the airbox. I figured if there was a way for the air to pass through it would produce less restriction than just right to the airbox. It also helps stop the rain from getting sucked up into my airbox and trashing my filter...It worked out well...
Another fine job of craftsmanship!
Old Apr 28, 2002 | 08:31 AM
Bone BSA's Avatar
where did you get the material oh red one???
Old Apr 28, 2002 | 08:40 AM
Dead's Avatar
Elder Member
Default The Get'n Place.
A commercial plastics wholesaler.
Old Apr 28, 2002 | 08:54 AM
Bone BSA's Avatar
Default Im guessing its local with a name like that
I need to find some insulating material Ive been trying to do the same thing for a long time
Old Apr 28, 2002 | 10:24 AM
Dead's Avatar
Elder Member
Default That was a joke,dufus.
The place is called Norell Plastics. Don't know if it's just a local place or not. Look in the YELLOW PAGES under plastics and call some of the places.When I do Jaime's it will be different due to the proximity of the turbo and the heat from up. I'll show you when it's done.
Old Apr 28, 2002 | 02:58 PM
Bone BSA's Avatar
Default oh oh oh a joke from JD....wow thats a first
ok Ill check em out thnx
Old Apr 29, 2002 | 10:13 PM
swett's Avatar
New Member
Default Did you have to move/remove anything to route it?
Did you have to move or remove any parts to route it from the lower grill into the airbox area?
Looks like a great setup. Does it feel better than stock?
-Ian
 Pouria Savadkouei
 Michael S. Palmer
Old May 1, 2002 | 05:06 AM
Dead's Avatar
Elder Member
I had to remove one horn.
Old May 1, 2002 | 03:54 PM
Lambo-Bully's Avatar
Default how about this?
<center><img src="http://pictureposter.audiworld.com/21967/p2100002.jpg"></center><p>It's got a strip of weatherstripping at the top now, seals right up to the hood.
