Power loss problem - Need Help/Suggestions!
12/10/00
Installed TAP Stage 1 Chip, K&N Filter, Supersprint Exhaust. Results were fantastic......excellent power, smooth and responsive
01/05/00
Installed cone intake system from Turbo5. Great sounds, faster spool up, more responsive throttle
01/13/00 PROBLEM OCCURRED
Under full throttle at 4000-5000 RPMS, I get a sudden power loss. If I back off the throttle for a second and then jump back on it, the power is there, but again drops when the revs come back up. Under moderate acceleration, this problem does not occur.
01/16/00
Replaced stock bypass valve with Bailey valve.......Problem still present, but at slightly higher RPM
Anyone experiened a similar problem? Any suggestions would be greatly appreciated!
I would think that such a leak would be between the turbo and the intake manifold, but I'm not sure.
Clark.......have you had any such reports with the intake system? Is there anything in the intake setup (cone filter thru MAF sensor) that would cause this problem? I went over the intake carefully, including the mounting of the MAF sensor and everything appears to be mounted correctly and all clamps are secure.
Any other suggestions? Car only has 9K miles........anyone have problems with pressure leaks?
Any ideas??
Maybe something's goofy with the maf. Moderate acceleration doesn't demand as much air, hence less impact on the MAF reading.
Doubt it's a boost leak, as the K03 spools up very low, and you'd know it way before 4-5k. Boost is boost, even at moderate acceleration.
With the new drive by wires, there is a boost sensor just after the IC, and it will cause a check engine light if boost falls.
