Performance and Tuning Discussion forum for various performance tuning techniques and questions
Redline question
Old Oct 6, 2006 | 04:37 AM
Audi4780's Avatar
Default Redline question
My buddies and I were curious on what parts would you need to upgrade inside a motor (Specifically 2.8L 30V) to "safely" increase its redline?
About how much would all the parts costs?
Old Oct 6, 2006 | 06:54 AM
JAFO's Avatar
Default iirc the ecu controls the rev-limiter.....
when i chipped my 1.8T the limit went from 6300 to 7200. with no engine mods.
Old Oct 6, 2006 | 03:21 PM
Audiboy's Avatar
Default It's a 90 degree block on a firing order that is optimum at angles divisible by 60
Not sure how much more you can gain without grenading the crank.
But as for higher RPM quests, it usually involves stiffer valve springs to return the valves faster, different profile on the cams, solid lifters, and stronger yet lighter, and well balanced bottom end components. Hopefully the timing belt and components are up to the task.
What are your goals? Why not stick to it's useable RPM and increase overall torque?
Old Oct 6, 2006 | 06:44 PM
Audi4780's Avatar
Default Re: It's a 90 degree block on a firing order that is optimum at angles divisible by 60
It was just a question my buddies and I were wondering. I am going to stick with its useable RPM's.
As far as increasing torque goes, what are the best parts to add/change? I would like to put a PES G2 supercharger on my motor if I can find one.
Old Oct 9, 2006 | 10:00 AM
Audiboy's Avatar
Default That's probably the most straight forward one. If you can locate a G1 for cheaper, you can even fab
intercooling which can enhance the performance a bit more. But the G1 was louder.
Other than PES, you'll be looking at custom forced induction, which at that point,would be better to source a used S4 imo, or transplant a 2.7T and custom or S4/A6 ECU and wiring.
Old Oct 19, 2006 | 11:17 AM
xr4tic's Avatar
Default RPM = "Ruins People's Motors"
just remember reading that somewhere, The Old One I think.
Anyways, it all depends on how well balanced the rotating assembly is, bore/stroke ratio has a big influence on how well an engine can breath
There will be a point where the valves will start to float on a stock head, and the more miles on the valvetrain, the earlier they will start to float.
More than likely, you can "safely" increase the RPM limit 500 or so easily, but doesn't mean it will actually do anything.
freeing up the intake and exhaust will need to be done at a minimum.
1-pippin
Sep 28, 2008 04:57 PM
TurboJew
Audi Original "S" Cars
Feb 15, 2006 08:14 PM
rs2audi
May 7, 2003 06:02 PM
A4TITUDE
Apr 11, 2002 07:45 PM
A4-2nr
Jun 4, 2001 09:59 AM
