Replace the catalytic converter.
I took a quick peep under our TTRQ a while back. It splits the work on to 2 cats mounted further downstream like @--<=>--D--[
Now if that doesn't help make 225hp stock, I'll be damned
But that twin intercooler setup has to go.
I noticed a big difference on the top end, not so much on the
If there was a 4-wheel dyno around here (MI) I'd have no problem doing a before/after test (I could test my WI setup too) I wonder if I can dyno with the driveshaft disconnected?
I'd love to see some numbers.
About catalysts: I think you are still using old-school catalyst theory. Cats used to plug up as they got older when they used a pelletized catalyst matrix (like a bed of gravel) which were also very restrictive. If they were overheated (common when hotrodded from overrich mixtures) and just from age the catalyst pellets broke down until you had a sand bed. Monolithic cats came next with a porous brick of catalyst that the exhaust flowed thru. These were great on Mercedes diesels because they trapped particulates well.
Modern catalysts use a metal matrix catalyst which doesn't tend to plug or break up with time, so I don't think catalyst age is a factor.
Metal matrix cats are also miles ahead in reduced backpressure compared to the older styles, which is why I stick to my guns with the 3-5 hp figures. You can go look it up in VW Performance Tuning, if you like, they give actual dyno numbers. Granted its not a turbo car, but I don't think you will get more than 5 hp mas out of it, and its still illegal as hell.
Thanks for the spitired debate!
there IS a large diffirence esp in the top end.
it is much more than 3hp, and i have no DTC's.
if i were using a straight pipe then i might get a code, but if your aftermarket cat runs at least somewhat efficiently you wont have a problem
look at my pics above, then tell me there wont be a noticibale diffirence. i couldnt even get any light to shine through the stock cat, thats why the pic was taken with the light behind it
I think my dad has (or has access to) a pressure gauge that you screw in place of the O2 sensor to check for a clogged cat/exhaust. If possible, I'll try to see if I can get my hands on it, although I'm not sure how well the car will run with the primary O2 sensor unplugged (although I could make the second O2 sensor the primary one, but it still might cause problems)
Since the exhaust is very turbulent coming out of the turbo, the first thing it will hit is the cells. Less cells = less restriction, and I'm curious if the more orderly arranged cells help by straightening the flow (much like a MAF screen does)
This would be an even bigger advantage on a K04 as opposed to a K03, since it flows more air and more exhaust.
The point here is every post that claims removal of the cat gives a big increase is not backed up with numbers.
The only test that would satisfy myself and the other critics is this:
Audi/Passat dyno - stock exhaust/cat vs. stock exhuast/no cat (or aftermarket cat)
Audi/Passat dyno - aftermarket exhaust (+downpipe)/cat vs. aftermarket exhaust (+downpipe)/no cat (or aftermarket cat)
Then this argument would end once and happily for all! ;-)
My instinct says 3-5hp on the stock dyno comparison, and maybe 5-7 on top of the aftermarket exhuast comparo.
Take care,
Michael
