Performance and Tuning Discussion forum for various performance tuning techniques and questions
Supercharger
Old Mar 10, 2003 | 11:10 AM
Supercoupe's Avatar
Default Supercharger
Would a G60 Supercharger from a 91 Corrado be sufficient boost pressure to improve a 85 CGT w/NG 2.3 or is it a waste of time?
Old Mar 10, 2003 | 12:37 PM
cuatrokoop's Avatar
Default Re: Supercharger
For one, unless you or someone previously swapped in the NG code engine, your '85 CGT does NOT have the 133hp engine. It'll have a 115hp 2.2L KX code 10v.
Two, the G60 is way undersized for a 2.2L I5 engine. You'd need to find a G80 or G100, neither of which exist to my knowledge.
Also, where to put it, and how to drive it from the crank pulley? Not much room to mount it, and unless you ditch the AC or power steering, you don't have a pulley to drive it from.
Just get an MC code 10v turbo, and drop it in. Very straight forward swap, its been done several times, lotsa information on the web about it...You can also use the bits from the MC, or even the older KH turbo, on your KX code engine with the proper ECU and have that work out pretty well. Your KX has 8.x:1 compression, and the KH has 7.8 as does the early MC (late MC has 8.3:1).
Old Mar 10, 2003 | 01:25 PM
Supercoupe's Avatar
I put in the NG and was just looking for something to do, thanks for the info.
Old Mar 10, 2003 | 01:29 PM
cuatrokoop's Avatar
well, since it does have the NG in it, you can't do much w/out dropping the CR if you don't want to swap a motor again.
Otherwise, get an MC code engine and wiring/ecu. 165hp, 177lb-ft, plus chipable to 230-250hp.
Old Mar 10, 2003 | 04:51 PM
Supercoupe's Avatar
thanx
Old Mar 11, 2003 | 01:43 AM
Merkin's Avatar
AudiWorld Expert
Default G100 bahahahaha
thats a good one
Old Mar 11, 2003 | 04:20 AM
cuatrokoop's Avatar
Default Re: G100 bahahahaha
heh... :-p
Just trying to say that the G60 is "itty" for a 2.3L... ;-)
p8ntball_89
12v V6 Discussion
Sep 2, 2022 05:36 AM
theaudiguy
Jan 5, 2004 10:29 PM
NOLAN5162
Audi A3 / S3 / RS 3
Dec 6, 2003 01:48 AM
süpercüp
Aug 25, 2002 12:19 AM
Bob Bruno
Aug 30, 2001 01:03 PM
