suspension install question
Thanks,
Jewel
btw, it's a 2001 1.8TQM
John.
You dont need to separate the front lower trailing arms as described in the manual. Without the right tool, removing that is a pain and will likely damage the boot. You can twist and push things about enough to remove and install the lower strut bolt without removing the trailing arm.
Observe the alignment of the shock and spring to each other and the mounting points before disassembling the strut and try to get the new ones back in this arrangement. I think the Bilstein's bottom mounts pivot which makes precise pre-adjustment unnecessary, but if yours dont, you have to get the top and bottom angles exactly right before releasing the spring compression or it wont go back into the car and cant be turned.
