Performance and Tuning Discussion forum for various performance tuning techniques and questions
Tec-II software
Old May 1, 2001 | 08:13 PM
Rob K's Avatar
Default Tec-II software
<center><img src="http://pictureposter.audiworld.com/620/engine_monitor.jpg"></center><p>Here are a few screen shots of the Tec-II software. They file loaded is one of the earlier files from the tuning process.
Old May 1, 2001 | 08:15 PM
Rob K's Avatar
Default Datalog screen
<center><img src="http://pictureposter.audiworld.com/620/datalog.jpg"></center><p>
Old May 1, 2001 | 08:16 PM
Rob K's Avatar
Default Air/fuel ratio graph
<center><img src="http://pictureposter.audiworld.com/620/af_table.jpg"></center><p>
Old May 1, 2001 | 08:23 PM
Rob K's Avatar
Default Basic Fueling Parameters
<center><img src="http://pictureposter.audiworld.com/620/injector_parameters.jpg"></center><p>This screen is where the basic fueling is extablished. TOG and IOT adjust the basic (linear)fuel curve. TOG is the injector pulse width at max load, it is used for setting fuel delivery at peak power, where fuel delivery is greatest. IOT offsets the entire raw fuel curve, and is used primarily to determine injector pulse width at idle. After a base fuel curve has been established, it is then modified at individual points by the use of a volumetric efficiency table. It is an effective, but easy approach to fueling.
Old May 1, 2001 | 08:27 PM
Rob K's Avatar
Default Ignition Advance
<center><img src="http://pictureposter.audiworld.com/620/ignition.jpg"></center><p>The ignition advance on this map is a fairly basic curve, and has been changed significantly aas I have had more time to tune it. This map is only set up for boost to 150KPA.
brucetimev8
VAG-COM Discussion
Feb 21, 2008 10:14 AM
Bliggity
Jun 21, 2005 03:49 PM
A Foore
Aug 11, 2004 07:33 AM
Cipher5170
Jun 28, 2003 12:53 PM
