Performance and Tuning Discussion forum for various performance tuning techniques and questions
Timing Questions...
Old Aug 27, 2003 | 06:00 AM
Stratocaster1422's Avatar
Member
Default Timing Questions...
So I have an OBDII pocket logger b/c it was free and I can't afford a laptop and VAG-Com yet. In reading the timing values, are postive values "timing advance" and negative values "timing retard"? If not, where is the "Zero position" that I can determine degrees of advance or retard? MY2000 A4 1.8TQM engine code ATW
I just did my TB and now I am in paranoia mode
Old Aug 27, 2003 | 06:39 AM
ModifiedA4's Avatar
Banned
Default you should post this in the vag-com forum.
you should read +30 at idle and it should drop, but not go negative, when you get on the gas.
Matt E.'s Avatar
Default I think that if your timing was off you'd REALLY be able to tell.
When I did the swap I just made sure to mark everything and line them back up. Took a few goes to get it lined up when adding tension to the belt but it was obvious when you had the belt lined up right. It was either on the right tooth or it wasnt.
Old Aug 27, 2003 | 06:54 AM
Member
Default yeah I believe those were the numbers I was getting...
forgot my palm pilot at home. I am going to do some runs at Kenny's later tonight. Every now and then I get blips of like -4. Is that knock when it hits negative?
Old Aug 27, 2003 | 07:04 AM
ModifiedA4's Avatar
Banned
seems ok then...when was the last time you ran techron and changed your spark plugs?
Old Aug 27, 2003 | 07:10 AM
Member
Default plugs a month ago...never ran techron in the 10K miles i have owned the car
I may need to drop my gap to .030 though...i set them at .032
Old Aug 27, 2003 | 07:26 AM
ModifiedA4's Avatar
Banned
Default well throw a bottle in!
it sounded like you will be doing some vag-com logs this weekend.
you should to 3rd gear runs to redline and log your MAF, timing, actual boost vs requested.
that should give an idication what could be wrong.
Old Aug 27, 2003 | 07:27 AM
ModifiedA4's Avatar
Banned
what plugs are you running?
 Michael S. Palmer
Old Aug 27, 2003 | 07:48 AM
Member
Denso Iridiums
Old Aug 27, 2003 | 07:53 AM
ModifiedA4's Avatar
Banned
Default you should run the same plugs as will-the-TB-god.
after much research i decided to go with stock plugs. i believe that is what will runs.
