Performance and Tuning Discussion forum for various performance tuning techniques and questions
Tiptronic
Old Aug 29, 2007 | 05:03 PM
S4audi22's Avatar
New Member
Default Tiptronic
I just bought a 01 S4 tiptronic and it seems to be always shifting into overdrive so when I step on the throttle it takes over half throttle to get it to move and feels like there is not alot of boost when it does. Has anyone had a problem with there N75 valve? I also have a check engine light on for secondary air injection with low flow and leak codes. I dont know if that would effect anything else. I could really use some help. Thanks guys.
Old Aug 30, 2007 | 12:15 PM
Vier Glühende Ringe's Avatar
Default Turbo bypass valves
Check your turbo bypass valves to make sure they hold vacuum, if they aren't then they can lower the
amount of vacuum supplied to the secondary air system and also affect boost performance.
Old Aug 30, 2007 | 09:59 PM
S4audi22's Avatar
New Member
Default Re: Turbo bypass valves
there not stock they are both forge dv and it has a problem with the idle too it will slightly surge at idle. I was driving on the freeway in traffic and once i hit 40mph foot slightly on the gas the tranny went into 5th and ran at 1400 rpm is that normal it seems everytime you want to get it to move you have to get it to kick down. Ill test the dv and see if it works.
Old Sep 6, 2007 | 07:04 AM
Default Leak codes?
If you have an intake leak then you should look in to that first.
Old Oct 15, 2007 | 02:33 PM
Nutch's Avatar
Are all gears highlighted in your instrument cluster? If so, your tranny is stuck in limp mode.
malinowskiski
Jun 6, 2011 11:17 AM
TGK
12
Dec 1, 2010 09:35 AM
Ballin'A4
1.8T Discussion
Jan 27, 2008 06:41 PM
stewarbd
Jul 13, 2007 01:52 PM
TTinHongKong
14
Oct 12, 2000 05:03 PM
