Performance and Tuning Discussion forum for various performance tuning techniques and questions
Turbo Timer
Old May 4, 2008 | 05:40 PM
pressurized2.0's Avatar
New Member
Default Turbo Timer
i have a 06' a4 2.0 quattro s-line and i was wondering if these cars require a turbo timer? because i have an integra thats turbo and i have a turbo timer
Old May 5, 2008 | 06:29 AM
A400's Avatar
Default FWIW, do a turbo timer to circulate water thru engine till it cools. I wouldnt run the entire car as
that really just allows the impeller to spin down. Putting in an inline water pump tied to the turbo timer allows me to pump water thru the entire engine, and turbo for 3-4 minutes which greatly reduces engine and turbo heat. It was really easy to do and the water pulp just mounts inline and forces water thru on the loop, it can also be tied to the fans to assist in underhood cooling. I find this to be much more effective in controlling heat than idling the car. Besides mine is a manual which makes after run stupid.
Old Jun 10, 2008 | 10:50 AM
Roger @ CA's Avatar
Default Sounds like a very interesting idea... but if the engine is off, the oil pump won't be pumping oil
through the lines... I guess coolant is more important to pump into the turbo though. Where did you locate the secondary water pump? Driver's side into the radiator?
PeaceOuTT
TT (Mk2) Discussion
Dec 12, 2007 01:18 PM
quattro_francois
Audi Original "S" Cars
Feb 5, 2004 08:03 AM
squishybot
Jul 22, 2003 08:20 PM
RedBlackYellow
Feb 28, 2002 01:34 PM
edhu
May 15, 2001 12:13 PM
