Performance and Tuning Discussion forum for various performance tuning techniques and questions
Wastegate
Old Jan 20, 2002 | 04:08 PM
WhiteLX's Avatar
New Member
Default Wastegate
I have up a couple wastegates off Audi 5000s and I was wondering what kind of HP levels they are able to support. It there a certain HP level when the wastegate is just too small to bleed off the amount of exhaust in order to keep the boost level in check?
Thanks,
Eric
Old Jan 20, 2002 | 09:16 PM
1 slow Audi's Avatar
Default Re: Wastegate
The more boost you run the smaler the waste gate can be cause it doesnt have to vent so much exhaust gases.
if you have a big turbo and you run low boost with smal waste gate (5-10psi)you are gona experience boost creep.
Old Jan 21, 2002 | 06:25 AM
snoogins's Avatar
What is "boost creep"?
Old Jan 21, 2002 | 07:52 AM
CMH's Avatar
CMH
Senior Member
Default It is when the wastegate cant let off the exhaust fast enough to keep the boost level
where you want it. It is the same thing as a boost spike.
Old Jan 21, 2002 | 12:25 PM
snoogins's Avatar
aka : "turbo lag"?...
Old Jan 21, 2002 | 02:19 PM
CMH's Avatar
CMH
Senior Member
Default No, turbo lag is the time it takes you to get boost. Boost creep/spike is when
you get too much boost. I guess you can call it wastegate lag. =)
Old Jan 21, 2002 | 07:32 PM
StevenH's Avatar
Member
Default Basically, the wastegate lets out exhaust gasses a different way to prevent the turbo(more)
Basically, the wastegate lets out some of the exhaust gasses through a different path than the turbine to prevent it from spinning to fast which would create too much boost. If it can't let out enough gas the turbo spins faster than you want it too creating more boost than you want which is boost creep.
Old Jan 21, 2002 | 10:26 PM
CMH's Avatar
CMH
Senior Member
That is what I said in my other reply up further.
 Pouria Savadkouei
 Michael S. Palmer
Old Jun 6, 2002 | 03:55 PM
a4blur's Avatar
Default Re: No, turbo lag is the time it takes you to get boost. Boost creep/spike is when
Thanks
xr4tic
21
Apr 10, 2004 03:48 PM
duct tape
Mar 1, 2003 06:24 PM
mdwsta4â„¢uroslut
Jul 17, 2002 02:24 PM
BLKPERL
Jun 27, 2002 11:02 AM
holychild666
Feb 25, 2002 03:31 PM
