What does this fault code mean?
Audi dealer can't seem to erase it.
They say it could be the fault of my Wett chip.
Anyone know more than that?
Thnx in adv.
The throttle position sensor is built into the TB, so you can't replace just the TPS (like you can on most cars)
If someone in your area has a similar car, you could try plugging your ECU into their car and see what happens.
You can run I believe its like block 81 for an alignment. Does the code trigger again when you reset it?
