Performance and Tuning Discussion forum for various performance tuning techniques and questions
Where to put the cat ?
Old Jan 14, 2003 | 12:29 PM
Elberoth's Avatar
Default Where to put the cat ?
I'm gonna do the custom exhaust on my car soon.
I heard somewhere that the way the OE cat is mounted on 1.8T engines is worst imaginable - straight to the turbo.
Do you thing that moving the cat 1m down the pipe would be beneficial ? I could replace the OE cat with random-tech high flow 2,5" cat for example. I can even do a 3" downpipe between the turbo and the cat.
Any ideas ?
Old Jan 14, 2003 | 12:50 PM
SameerP's Avatar
Default Sure you can move it, and you don't need a metallic cat, ceramic will suffice...
what you could do is have a ceramic 3" in/out Catco cat put somewhere downstream, like replacing the resonator, or welded into a mid-pipe. Id just leave the O2's in the test pipe and use an emulator to eliminate the CEL.
That is what i plan to do in the near future. Since the temps are lower, a $200 catco is all you need. Look at what the GTI folks are doing.
Cheers,
Sameer
Old Jan 14, 2003 | 02:46 PM
Elberoth's Avatar
Will I gain anything just by moving the stock one ?
Old Jan 14, 2003 | 02:55 PM
Audi2ptzero's Avatar
Elder Member
Default A little less heat in the engine bay.
But you will still have the same back pressure.
Old Jan 14, 2003 | 03:05 PM
Elberoth's Avatar
I thought that maybe putting a 3" downpipe before the cat would help somehow
Old Jan 14, 2003 | 03:42 PM
SameerP's Avatar
Default look at the OEM cat, its not a straight in, straight out...
its curved significantly on the outlet side. So to use it, id assume you cannot just weld it into a mid-pipe. A 3" in/out catco is just straight in and straight out.
Besides, you do not want the narrow restrictions if you are going for power. To have a 3" DP is great, but then why have a 2" inlet, 2.25" outlet OEM cat as a bottleneck in the middle of your system?
Cheers,
Sameer
Old Jan 14, 2003 | 03:46 PM
Elberoth's Avatar
You're right. 2,5" Hi-Flow cat will set me back 200$ - is it a cost efective upgrade ?
Old Jan 14, 2003 | 03:47 PM
AXE's Avatar
AXE
Junior Member
Default I have a 3" downpipe, with a 3" cat under the car.
The turbo spools noticeabley quicker.
I think it's definately worth it.
Old Jan 14, 2003 | 03:50 PM
Elberoth's Avatar
Does it tapper to 2,5" after the cat ?
Old Jan 14, 2003 | 03:52 PM
AXE's Avatar
AXE
Junior Member
No .. 3" all the way through
