X-post: Help with Boost Spikes
<img src="http://d.pramanik.home.comcast.net/post/spikes3.gif"><ul><li><a href="https://forums.audiworld.com/s4/msgs/1411982.phtml">https://forums.audiworld.com/s4/msgs/1411982.phtml</a</li></ul>
<img src="http://www.joepmbc.com/site_files/xz.jpg">
... installed in this fashion:
<img src="http://www.boostvalve.com/images/1.8T_n75_bv.jpg">
-Dave Pramanik
Good luck.
I was hoping to install it today, but didn't get that far. I did discover (via pressure testing) that the dealership failed to install a clamp on my MAP sensor when they replaced the torn tbb. :-/ Once I got a clamp on that, I didn't find any other boost leaks. Boost is still spiking though.
Really all I need to do is open the wastegates at a perscribed level (~1.2 bar), since the N75 is failing to do that in a timely fashion. After the initial spike, the N75 is adequate in controlling boost. If the MBC works as advertised, it should do the trick. I'll definitely report back once I've got it install and test it out.
-Dave Pramanik<ul><li><a href="https://forums.audiworld.com/s4/msgs/1389851.phtml">https://forums.audiworld.com/s4/msgs/1389851.phtml</a</li></ul>
