Yet another 2.0 conversion update.....
<a href="http://johnbaas.dyndns.org/2point0/audi_eng_in.jpg"><img src="http://johnbaas.dyndns.org/2point0/audi_eng_in_lo.jpg"></a>
I still have a couple of things to take care of:
1. Timing belt
2. Turbo plumbing
3. Downpipe
The K03 is sitting on top, and you can roughly see the angle it use to sit at. I had to hack the wastegate actuator mount to get it to sit where it's at now.
I'm not sure if I want to mount the turbo like this, or like stock. If I leave it like it is, it should make it easier to run tubing for a FMIC.
If I mount it in the stock postion, I need to fab a new wastegate mount since the wastegate actuator needs to stay in the position it's at. The bonus of mounting it in the stock position, is I should be able to use the stock outlet hose (one less part to fab up)
<a href="http://johnbaas.dyndns.org/2point0/audi_turbo_in.jpg"><img src="http://johnbaas.dyndns.org/2point0/audi_turbo_in_lo.jpg"></a>
ARP main studs installed:
<a href="http://johnbaas.dyndns.org/2point0/audi_main_studs.jpg"><img src="http://johnbaas.dyndns.org/2point0/audi_main_studs_lo.jpg"></a>
Picture of the engine mount adapter:
<a href="http://johnbaas.dyndns.org/2point0/audi_mount_adapter.jpg"><img src="http://johnbaas.dyndns.org/2point0/audi_mount_adapter_lo.jpg"></a>
Turbo coolant return mounted in the freeze plug
<a href="http://johnbaas.dyndns.org/2point0/audi_water_return.jpg"><img src="http://johnbaas.dyndns.org/2point0/audi_water_return_lo.jpg"></a>
Oil pressure sender installed:
<a href="http://johnbaas.dyndns.org/2point0/audi_oil_press.jpg"><img src="http://johnbaas.dyndns.org/2point0/audi_oil_press_lo.jpg"></a>
Dist hole plug washer:
<a href="http://johnbaas.dyndns.org/2point0/audi_dist_plug_1.jpg"><img src="http://johnbaas.dyndns.org/2point0/audi_dist_plug_1_lo.jpg"></a>
Installed (I sealed it up with silicone):
<a href="http://johnbaas.dyndns.org/2point0/audi_dist_plug_2.jpg"><img src="http://johnbaas.dyndns.org/2point0/audi_dist_plug_2_lo.jpg"></a>
Mmmmmm, clutchy goodness........
<a href="http://johnbaas.dyndns.org/2point0/audi_WoA_clutch.jpg"><img src="http://johnbaas.dyndns.org/2point0/audi_WoA_clutch_lo.jpg"></a>
Before I started, I measured the clearance available, it was about 2", so there's room
