2013 MMI without navigation
Old Oct 30, 2012 | 05:26 AM
Yoshimura's Avatar
Default 2013 MMI without navigation
Does the 2013 without navigation have the new MMI system (nicer interface, high resolutioon screen) as with navigation?
Old Oct 30, 2012 | 05:47 AM
Yoshimura's Avatar
This 2013 without nav seems to have the same old CANBus radio as non-nav 09-12.
http://www.autotrader.com/AtCarId/AT-13B74B2F
I don't why it has the I-NAV button on the streering wheel...
Old Oct 30, 2012 | 06:15 AM
spijun's Avatar
Tech Guru
Tech Guru
It is easier to make than that there is a special model with button NAV and without button NAV
Old model Q5 had a button for voice commands, although it did not exist - for model without NAV
Old Oct 30, 2012 | 07:52 AM
rdA4WtQ5's Avatar
My voice command button works just fine without nav. I can make phone calls with it.
Old Oct 30, 2012 | 07:59 AM
spijun's Avatar
Tech Guru
Tech Guru
Only phone calls, not the factory enabled, but I've enabled with vag-com
Old Oct 30, 2012 | 08:20 AM
rdA4WtQ5's Avatar
Only phone calls not the factory enabled, but I've enabled with vag-com
What else can be enabled non-nav with vag-com?
Only phone works on mine.
Old Oct 30, 2012 | 10:27 AM
spijun's Avatar
Tech Guru
Tech Guru
Phone voice control: Cars without full speech dialogue system, but a phone-prep or an Audi Bluetooth phone, come standard with phone speech control. However, it is not enabled or fully enabled in all markets. In the U.S. it is fully disabled (some reports of info from dealers/Audi claim problems if enabling it), in some other markets it is set in limited mode that only allows saving and selecting of voice tags, not actual speech dialogue with the phone. Luckily you can change this with VAG-COM by editing module Telephone (77), Coding, and changing the second last digit in Software coding, options are e.g.: 0 disabled, 2 English UK, 9 allow only voice tags. So if you have it set to 9, changing it to 2 would enable phone-related speech dialogue which you can try out by saying HELP. There are a few different languages built in too. For references see this fine AudiWorld thread
http://a6retrofit.tripod.com/article...des.html#codes
http://www.audienthusiasts.com/VagComTelephone.html
Old Oct 30, 2012 | 12:32 PM
rdA4WtQ5's Avatar
Thanks
The thread" https://forums.audiworld.com/a5/msgs/15745.phtml "
says to use 7 for English USA instead of 9 English United Kingdom.
Do they both work? Any differences? I always appreciate your knowledge.
Old Oct 30, 2012 | 01:10 PM
spijun's Avatar
Tech Guru
Tech Guru
I did not test, maybe there is a little difference
I have used this and there's a 2 = English (United Kingdom) and 7 = English (USA)
Old Oct 30, 2012 | 01:29 PM
rdA4WtQ5's Avatar
My code already is 0010370 and it won't take 0010320 to even try.
Thanks
