Brake upgrades
Old Dec 18, 2012 | 12:49 AM
hookooehoo's Avatar
Default Brake upgrades
Hi All, I didn't see anything on this so I thought I would ask. I noticed my pads are getting pretty low, so I thought I would start looking for new brakes before the sensor trips. As I started looking around I noticed some pads come with the wear sensor and some don't. This will be my first time doing the brakes on the audi (i do brakes on all my other cars, nothing new for me).
What I am wondering is does the wear sensor just move over to the new pads (looking at aftermarket, Power Stop, Brembo, EBC or Hawk) or do I need to buy pads that come with a new sensor lead?
Also does anyone have any experience running pads and rotors other then Audi parts? If so what did you like, not like, etc......
thanks for the insight.
Old Dec 18, 2012 | 02:42 AM
spijun's Avatar
Tech Guru
Tech Guru
See this:
http://www.adamsrotors.com/gallery/?gallery=1
Maybe you have the answer here
https://www.audiworld.com/forums/sho...ht=pads&page=2
Old Dec 18, 2012 | 10:36 AM
hookooehoo's Avatar
spijun thanks for the reply. I think I got most my answers, but now it sounds like I will need to get a VAG-COM to properly do the rear brakes.
Old Dec 18, 2012 | 10:52 AM
spijun's Avatar
Tech Guru
Tech Guru
True, you need VAG-COM for rear brakes.
Can search for of whether a from this forum has in your area with VAG-COM
Old Dec 18, 2012 | 08:08 PM
BirdmanQ5's Avatar
Not that I'm an expert at this, but I'm pretty sure you can skip out on the rear pads since they probably haven't worn nearly as much as the fronts.
As for aftermarket stuff, I first went with Hawk Ceramic pads on OEM rotors. After 20,000kms the rotors warped more than my sense of humour. Next, I purchased Adam's Rotors with POSI-Quiet semi metallic pads. They're alright, they don't feel nearly as nice as OEM, but I have yet to see how they fare in winter weather.
Moral of the story? Stick with OEM equipment. Unless you're gonna spend thousands on a full Brembo or Stoptech big brake upgrade.
Old Dec 19, 2012 | 07:32 PM
hookooehoo's Avatar
BirdmanQ5 - Yeah normally that is true, but I just checked all for corners and all are pads are low. They are all thinner then the metal bracket they are mounted too. My rule of thumb is to start looking once the pad is thinner then the bracket it is mounted too.
Not sure what brand I want to go with. Was hoping PowerStop had a kit, but its not looking like they do a rotor/pad kit. But I can get pads from them. I would love to do the BBK from Brembo, but Im not wanting to spend that money right now. Maybe next time around.
Old Dec 19, 2012 | 07:55 PM
BirdmanQ5's Avatar
This is my kit from Adams Rotors
1 - Q5/Q7 (Q5, Front & rear axles, 2011) $450.00
1 - Hub Coating (Front & rear axles, matte red) $50.00
1 - Rotor Finish (silver zinc, Front & rear axles) $0.00
1 - Pads & SS Lines (POSI-Quiet pads only, Front & rear axles) $180.00
1 - Pattern (race [double slot] requires coated hubs, Front & rear axles) $0.00
Total: $630.00
It's a good aftermarket setup if you don't want to shell out the money for OEM equipment. OEM was $1400 for 4 corners IIRC. If money isn't the issue, then go with Brembo, they're putting that on the new Q5s anyway
Old Dec 19, 2012 | 07:59 PM
BirdmanQ5's Avatar
Oh, a note about Adam's Rotors, don't bother with the painted hubs. It starts to look real crappy after only 5 months. You have to purchase painted hubs to get certain rotor designs, but I'd recommend just paying for it and sticking with the zinc finish. This is what my rotors look like, I'll paint them and the spacers black in the spring.
Old Dec 20, 2012 | 12:19 PM
COD's Avatar
COD
you have two models for new Q5 2013:
BREMBO front 320X30MM 5/112
BREMBO front 345X30MM 5/112
and for SQ5
ATE-TEVES (ATE Bremsen) front 380X36MM 5/112
Audi Q5 2013 has different (bigger) set of winter rims - BREMBO brakes are bigger so you have to check what kind of winter rims you have.
Old Jan 17, 2013 | 10:41 AM
hookooehoo's Avatar
I still have not done the brakes yet. Been shopping around and deciding what i want too do. Has anyone out there used the EBC Stage 5 kit? Includes the YellowStuff pads and rotors to match?
Also with pretty much all of my other vehicles i have changed the rubber brake lines to braided ones. Anyone done this also?
