Break-In Period
Keith
http://www.imakenews.com/bernardiaud....cfm?x=b11,0,w
, but no trips back to the dealer, no issues, car likes to accelerate from a stop as soon as the turbo spools which is like 1 sec. I am pleased so far.
"The process of engine break-in starts with low revs and about one-quarter throttle. Gradually, you rev a little higher and add a little more throttle. During this period, don’t keep the engine revs high for a long time. The idea is to gradually use more and more of the rev range, allowing the engine parts to wear-harden over time. The break-in for today’s engines is generally 700 to 1,000 miles.
One thing that hasn’t changed with engine break-in is the need for an early oil change. While the recommended oil change intervals for modern cars and trucks have been extended, the break-in oil and filter change should occur around 1,000 miles. This will clean out any fine metal particles dislodged in the first miles you put on your new car. Once those are out of the engine, you should be good to go, and go and go."
And what is considered a short amount of time? 5 seconds? 1 minute? 5 minutes? An hour?
We tried to avoid staying at a constant speed, which seems to be impossible in Europe anyway!
We did cruise a long at 110 mph several times effortlessly at low rpms...very smooth and feels like you're only going 85-90! 2100 miles and all is good! I guess we'll all find out down the road whose break-in process works for them! Good luck to all of us!
