Problem with SD card.
Old Aug 24, 2013 | 11:14 AM
tomaszp72's Avatar
Default Problem with SD card.
I wonder if anybody has seen a similar problem with the SD card reader in the MMI.
I have an SD card loaded with music. It worked fine for a long time on my previous Q5 and my current but recenlty it will work fine and then all of the sudden it will display some tracks as damaged. If I remove the card and put it back in the track that supposedly was damaged will play fine, but then after a while it will break again. These broken tracks are grayed out. I'm trying to figure out if my SD card is going bad or it is the MMI.
Old Aug 24, 2013 | 02:42 PM
Bob Petruska's Avatar
25 Year Member
One thing to try is copy your card back to your computer, then copy the music files to a new SD card. If that works fine then reformat your old SD card for later use. SD cards are dirt cheap, less than a $1 per GB.
Old Aug 24, 2013 | 02:55 PM
Reggie's Avatar
Club AutoUnion
25 Year Member
Also I hope he is not using one of the mini sd cards with an adapter - those connections get bad after a while
Old Aug 24, 2013 | 03:23 PM
tomaszp72's Avatar
Nope, just a regula SD card.
I copied stuff before to the comupter from this card and it worked fine. I will buy another card and try it.
Tom10
Audi A3 / S3 / RS 3
10
Jul 8, 2018 09:30 AM
abpuma
Sep 17, 2015 11:39 AM
suavetony
9
Sep 13, 2015 05:17 PM
supra725
S4 (B8 Platform) Discussion
Sep 13, 2015 08:59 AM
alin.zalau
Q7 MK 1 Discussion
Sep 12, 2015 01:09 PM
