Q5 TDI Rough idle when cold
I never mentioned sub (-) 40* temps where simply starting a cold soaked anything would be difficult if not impossible. I was asking about temps below (+) 40* which Tulsa does experience on a fairly regular basis.
Yes, I used white bottle PS in the winter, gray bottle PS the rest of the year in my '01 ALH Jetta and am currently experimenting with XPD in the '12 CJAA Jetta.
Yes, I have heard of coolant heaters. Other than 1 hard starting episode with a bad tank of fuel and (-) 25* cold soaking in South Park, CO with the '01, I have not been to justify the use of one.
Unless your car spends the night outside in the conditions I have indicated, you will not know if it exhibits this behavior or not.
Again, thanks for your response.
That Q7 TDI had 2500 miles on it, almost new looking inside and out, and no obvious issues. Q7's are now way long in the design tooth, and maybe the motor mounts or something were another step behind generation wise.It is also at a marginally lower tune than the Q5 TDI, and the Q7 is a real porker weight wise. Still my question there was about the NVH (and possible boost lag), not the heft or acceleration, which was decent. Some incremental idle vibration doesn't surprise me in general given both the higher compression and the self ignition. Much less than older diesels. But it was perceptible in both the steering wheel and even in the pedal some if I was thinking about it. Not like a rude heavy duty/construction type vehicle by any stretch, but also not transparent.
I was interested in it for a possible alternative to a 3.0T, but unfortunately ran into some pretty over the top zealot stuff on the other board where I had the vehicle interest and couldn't get a direct answer to what I had run into w/ the Q7. It was kind of a turn off.
I have a Q5 TDI and an A6 TDI, and they both idle smoothly in cold temps (20 to 40 F).
I've spent lots of time in a variety of Q7 TDIs here, and other diesel models in Europe, and there's no question, the Q7 just isn't as well insulated or something, because the A6, A7 and A8 TDIs are much quieter, much less "dieselish".
I have yet to sample the US spec A6 a7 or a8 TDI though, so I'll hold off final judgement till I do.
Regarding the boost lag comment, I think that comes down to turbo design and size. I've never really thought the Q7 TDI was overly laggy, but all diesels will feel a little "slow revving" compared to a gas engine.
Compared to the Cummins engine in our old Dodge truck, the Q7 is absolutely silky smooth. =)
Thanks for the reply.
