15 Q7 TPMS and ESC fault?
Club AutoUnion
I bought this 2015 TDI brand new and am the original owner. All maintenance or whatever was required per manual and recommendations at the dealer (filters, oil changes, ad blue, tire rotations, and alignment and such except brake pads as they are is great condition). This vehicle is rarely used and is mostly garage kept and only used for long road trips. Currently shy of 40k but I had not driven the vehicle for about 2 months (battery was being charged) and just took it out of the garage and noticed the ESC fault come on as well as TPMS. I am just worried if this ABS module issue? Why at such low mileage and why now? I am using I think 21 or 22 in rims. All I have done was change tires to Continental ExtremeContact DWS06 15K miles ago by FireStone Complete Auto Care that also comes with lifetime alignment etc. and was going to have them diagnose the issue since I was going to go there for alignment if it needed it and check the sensors (I go every 6 months to get it calibrated).
Things to know:
1. Took the vehicle to Audi dealership to get oil change and they rotated the tires recently a week ago, lights were not on at the time. Can't go back as they are about an hour and 30 minutes (out of state) from where I currently am.
2. The car is now shaking or at least I can't go past 70-75mph without the steering wheel vibrating and shaking as well as the whole car. This started as soon as the tires were rotated. I plan to change the tires back to where they were.
3. I am planning to take the vehicle on a long road strip (about 1,400 miles) cross country today in a couple of hours as brakes etc all work. I checked the tire pressures and they are all correct per specs.
4. Don't have access to the Vag-Com to check faults as the wires are at the destination I am heading to so was going to check it there.
5. I suspect ABS module or sensor on the rear based on my research? Any suggestions on what I should check and where?
Things to know:
Sounds like you have a wheel/tire badly out of balance.....if it shaking bad enough it's possible it would throw off the wheel speed sensor, which is used for both TPMS and ESC.
Club AutoUnion
Edit:
I will note that when I bought the car new, it was having soo much tire noise like it was a jet engine or something but I dealt with it until I changed tires with alignment and has been so quiet until the obvious tire rotations done that has caused this issue.
Perhaps a bent wheel, etc. See if you can find a shop that uses a Hunter Road Force loaded balancer.
uberwgn (05-13-2021)
Do you have air suspension? You can get faults like this from water in the system
Club AutoUnion
Update:
So before the trip, I ended up rotating the tires back to where they originally were and my god the ride is back to being smooth as butter but if going at 80mph, I can hear odd sound and I suspect one of the rims/tires. Overall, my trip is going pleasantly. Would've drove me crazy driving the car shaking etc.
During my trip, I drove approximately 1000 miles. I saw the ESC Fault go away and come back after a couple hundred miles but the tpms would stay on. I would also note that while rotating tires back, there was lots of brake dust all over the wires etc. Would that be a cause? Can someone point which one is the sensor as the only sensor I noticed other than the headlight leveling was the connector near the brake caliper and lines.
Here is picture while driving, I saw the ESC Fault go away suddenly at 237 miles into the trip. Came back on at 450 mile mark. I will use the Ross tech cable and scan for Faults next.
Currently still on the road and just took a break but will update after I arrive.
Have you gone into the MMI and told it to reset the TPMS?
It should have reset after driving 1000 miles but maybe it needs to be told so.
This is for a pre-facelift but should be the same or close enough, #28 and #6 in these diagrams.
Club AutoUnion
Thank you for that informative diagram.
Quick update: Finished my trip, however issue persisted all the way but more.
The Brake light started turning on and off now and even the adaptive light defective malfunction. The adaptive light malfunction turns on only when the brake light turns on. At this point it's a Christmas tree on the instrument cluster. This just started after like 20 minutes of my drive left for the journey.
So just scanned the vehicle and here are the Faults. Can't believe so many faults and all seem to be related to abs module and or possibly battery? Seems like battery is not providing proper voltage? I will say that I did use an inverter hooked up to the vehicle for laptop use for work. May have drained battery and caused electrical issues? Although this was never an issue in the past couple of years. Is it time to replace the battery?
Fault Codes:
Code:
Friday,14,May,2021,13:53:39:06855 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64 VCDS Version: 21.3.0.0 (x64) Data version: 20210226 DS325.0 www.Ross-Tech.com VIN: WA1WMAFEXFD015639 License Plate: Chassis Type: FE-AU56 (4F0) Scan: 01 02 03 05 08 09 10 15 16 17 19 28 36 3C 42 46 47 4C 4F 52 55 56 5F 62 69 6C 6D 6F 72 VIN: WA1WMAFEXFD015639 Mileage: 65690km-40817miles 01-Engine -- Status: Malfunction 0010 02-Auto Trans -- Status: Malfunction 0010 03-ABS Brakes -- Status: Malfunction 0010 04-Steering Angle -- Status: OK 0000 05-Acc/Start Auth. -- Status: Malfunction 0010 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: OK 0000 10-Park/Steer Assist -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 28-HVAC, Rear -- Status: OK 0000 36-Seat Mem. Drvr -- Status: OK 0000 3C-Lane Change -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 46-Central Conv. -- Status: Malfunction 0010 47-Sound System -- Status: OK 0000 4C-Tire Pressure II -- Status: Malfunction 0010 4F-Centr. Electr. II -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 55-Headlight Range -- Status: Malfunction 0010 56-Radio -- Status: OK 0000 5F-Information Electr. -- Status: OK 0000 62-Door, Rear Left -- Status: OK 0000 69-Trailer -- Status: Malfunction 0010 6C-Back-up Cam. -- Status: OK 0000 6D-Trunk Elect. -- Status: OK 0000 6F-Centr. Conv. II -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine (J623-CNRB) Labels:. 059-907-401-V2.clb Part No SW: 4L2 910 401 A HW: 4L0 907 401 E Component: 3.0TDI EDC17 H23 0007 Revision: 54H23--- Serial number: Coding: 2A2A4012253600050000 Shop #: WSC 31414 790 00001 ASAM Dataset: EV_ECM30TDI0114L2910401A 001008 ROD: EV_ECM30TDI0114L2910401A.rod VCID: 224BF69535D5369BF5-8076 5 Faults Found: 5453 - Starter Relay P3088 00 [096] - Electrical Malfunction Intermittent - Not Confirmed - Tested Since Memory Clear 5456 - Starter Will Not Turn P3054 00 [096] - Jammed or Electrical Malfunction Intermittent - Not Confirmed - Tested Since Memory Clear 4675 - Please Check Fault Codes in Control Module for ABS Brakes U1017 00 [044] - - [New feature! Extended UDS fault detail is only supported by current gen. interfaces] Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 5 Mileage: 63869 km Date: 2021.04.16 Time: 19:34:00 Engine RPM: 0.00 /min Normed load value: 0.0 % Vehicle speed: 0 km/h Coolant temperature: 12 °C Intake air temperature: 14 °C Ambient air pressure: 970 mbar Voltage terminal 30: 10.920 V Unlearning counter according OBD: 40 Limitation: accelerator pedal: 0.0 Nm CAN status - engine control module-Bits 0-7: 0 Cruise Control System (CCS): status-Bits 0-7: 47 CAN status - transmission control module-Bits 0-7: 0 CAN status - brake control module 1-Bits 0-7: 0 CAN status - brake control module 2-Bits 0-7: 0 selected gear-Bits 0-7: 0 17262 - Terminal 30 U140A 00 [032] - Open Circuit [New feature! Extended UDS fault detail is only supported by current gen. interfaces] Intermittent - Not Confirmed - Tested Since Memory Clear 4629 - ECM Power Relay Load Circuit P068A 00 [032] - Opens Too Early Intermittent - Not Confirmed - Tested Since Memory Clear Readiness: 0 0 0 0 0 ------------------------------------------------------------------------------- Address 02: Auto Trans (J217) Labels:| 0C8-927-750.clb Part No SW: 0C8 927 750 AQ HW: 0C8 927 750 AQ Component: AL1000 AISIN 002 2454 Serial number: Coding: 001378 Shop #: WSC 03206 002 1048576 ASAM Dataset: EV_TCMAL991031 002114 ROD: EV_TCMAL991031_002.rod VCID: 7BF5EBF1F2FFA75396-802E 2 Faults Found: 12835 - Implausible Data Received from ABS Control Module U0415 00 [008] - - Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 2 Reset counter: 197 Mileage: 0 km Date: 2013.02.27 Time: 00:00:11 Engine RPM: 1410.0 /min Transmission input speed: 1020 /min Transmission output speed: 360 /min Engine torque: 104 Nm ATF temperature: 78 °C Accelerator pedal position: 19.6 % Clutch_C1: closed Clutch_C2: Open Clutch_C3: Open Clutch_C4: Open Clutch_B1: Open Clutch_B2: Open Lock Up Clutch: Open EOP target revolution: 65534 /min EOP actual revolution: 65279 /min Engine Speed signal Current: 65279 /min EOP failure status with EOP without HV 1: Motor normal stop EOP target current: 65278 mA 12837 - Implausible Data Received from ABS Control Module U0415 00 [008] - - Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 3 Reset counter: 197 Mileage: 0 km Date: 2013.02.27 Time: 00:00:11 Engine RPM: 810.0 /min Transmission input speed: 780 /min Transmission output speed: 0 /min Engine torque: 32 Nm ATF temperature: 78 °C Accelerator pedal position: 0.0 % Clutch_C1: Open Clutch_C2: Open Clutch_C3: Open Clutch_C4: Open Clutch_B1: Open Clutch_B2: Open Lock Up Clutch: Open EOP target revolution: 65534 /min EOP actual revolution: 65279 /min Engine Speed signal Current: 65279 /min EOP failure status with EOP without HV 1: Motor normal stop EOP target current: 65278 mA ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels:. 4L0-910-517-V2.clb Part No SW: 4L0 910 517 M HW: 4L0 614 517 L Component: ESP ALLRAD MK25E1 0020 Revision: 00H02001 Coding: 0099441 Shop #: WSC 31414 790 00001 VCID: 346700CD5721A82B17-8060 6 Faults Found: 00283 - ABS Wheel Speed Sensor; Front Left (G47) 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 2 Fault Frequency: 2 Reset counter: 33 Mileage: 63869 km Time Indication: 0 Freeze Frame: Count: 192 Count: 833 Count: 38 Count: 39424 00668 - Supply Voltage Terminal 30 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 2 Fault Frequency: 2 Reset counter: 32 Mileage: 63869 km Time Indication: 0 Date: 2021.04.16 Time: 19:34:00 Freeze Frame: Count: 192 Count: 833 Count: 128 Count: 38912 00290 - ABS Wheel Speed Sensor; Rear Left (G46) 003 - Mechanical Failure - Intermittent Freeze Frame: Fault Status: 00100011 Fault Priority: 2 Fault Frequency: 1 Reset counter: 39 Mileage: 65124 km Time Indication: 0 Date: 2021.05.14 Time: 07:42:30 Freeze Frame: Count: 0 Count: 8195 Count: 75 Count: 50432 00287 - ABS Wheel Speed Sensor; Rear Right (G44) 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 2 Fault Frequency: 2 Reset counter: 254 Mileage: 64060 km Time Indication: 0 Freeze Frame: Count: 192 Count: 833 Count: 86 Count: 41984 00290 - ABS Wheel Speed Sensor; Rear Left (G46) 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 2 Fault Frequency: 2 Reset counter: 254 Mileage: 65124 km Time Indication: 0 Date: 2021.05.14 Time: 07:35:39 Freeze Frame: Count: 320 Count: 8259 Count: 73 Count: 47104 00814 - Solenoid for Brake Pressure (N247) 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 01101100 Fault Priority: 2 Fault Frequency: 5 Reset counter: 254 Mileage: 61603 km Time Indication: 0 Freeze Frame: Count: 128 Count: 833 Count: 99 Count: 40192 ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. Labels:. 4F0-910-852.clb Part No SW: 4F0 910 852 B HW: 4F0 905 852 H Component: FBSAUDIC6 ELV H08 0210 Revision: 00H08000 Serial number: 10603902184301 Coding: 0000135 Shop #: WSC 31414 790 00001 VCID: 2541ED89ECFBC1A390-8070 Subsystem 1 - Part No: 4F0 910 132 L Component: FBSAUDIC6 EZS H05 0020 Subsystem 2 - Part No: 4F0 910 335 B Component: FBSAUDIC6 KSG H03 0020 2 Faults Found: 00191 - Passenger's Door Handle Touch Sensor (G416) 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00110111 Fault Priority: 3 Fault Frequency: 1 Reset counter: 38 Time Indication: 0 00191 - Passenger's Door Handle Touch Sensor (G416) 007 - Short to Ground - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 3 Fault Frequency: 3 Reset counter: 38 Mileage: 64036 km Time Indication: 0 Date: 2021.05.13 Time: 15:42:47 ------------------------------------------------------------------------------- Address 08: Auto HVAC (J255) Labels: None Part No SW: 4L0 910 043 D HW: 4L0 820 043 AQ Component: KLIMA 4 ZONEN H15 0070 Revision: 00---031 Serial number: 00000000461021 Coding: 0304A036 Shop #: WSC 31414 790 00001 VCID: 2541ED892CFBC1A390-8070 Subsystem 1 - Part No SW: 8K0 959 772 F HW: 8K0 959 772 Component: SLR-B8 H06 0007 Serial number: 0132731213 Coding: 070000 Subsystem 2 - Part No SW: 8K0 959 772 F HW: 8K0 959 772 Component: SLR-B8 H06 0007 Serial number: 0132730159 Coding: 070000 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 4F0-910-279.lbl Part No SW: 4F0 910 279 AG HW: 4F0 907 279 C Component: ILM Fahrer H31 0400 Revision: 00000000 Serial number: 4F0907279 Coding: 0133123 Shop #: WSC 31414 790 00001 VCID: 6ED3D2A5798DC2FB21-803A Subsystem 1 - Part No: 4L1 910 113 Labels: 1KX-955-119.CLB Component: Wischer AU716 H18 0110 Coding: 00064792 Shop #: WSC 31414 Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB Component: REGENLICHTSENSORH04 0003 Coding: 00150059 Shop #: WSC 31414 No fault code found. ------------------------------------------------------------------------------- Address 10: Park/Steer Assist (J446) Labels:| 4L0-919-475-7X2.clb Part No SW: 4L0 919 475 A HW: 4H0 919 475 C Component: PARKHILFE 8K H07 0011 Revision: 11001001 Serial number: 55931501600240 Coding: 29011F Shop #: WSC 31414 790 00001 ASAM Dataset: EV_EPHVA18AU7160000 001001 ROD: EV_EPHVA18AU7160000.rod VCID: 346700CD9F21A82B17-8060 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: 4L0-910-655.lbl Part No SW: 4L0 910 655 A HW: 4L0 959 655 B Component: 73 AIRBAG AUDI8RH45 0230 Revision: 09H45000 Serial number: 0038QD90HCLN Coding: 0014131 Shop #: WSC 31414 790 00001 VCID: 2B551BB18A1FF7D346-807E Subsystem 1 - Part No: 4L0 959 339 C Component: BF-Gewichtsens. H05 0040 Subsystem 2 - Serial number: 6332QSME514C1462A Subsystem 3 - Serial number: 6342QSME544C4874O Subsystem 4 - Serial number: 6352QSME154D0E56P Subsystem 5 - Serial number: 6362QSME514C0948L Subsystem 6 - Serial number: 63734SME7C4B5358D Subsystem 7 - Serial number: 63834SME7C4B307CF No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 4F0-910-549.lbl Part No SW: 4F0 910 549 B HW: 4F0 953 549 E Component: J0527 0830 Revision: 00H09000 Serial number: 90026143570090 Coding: 0012142 Shop #: WSC 31414 790 00001 VCID: 285FE4BD9BE9DCCBAB-807C Subsystem 1 - Part No: XXXXXXXXXXX Component: E0221 H03 0040 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels:. 4L0-920-xxx-17.clb Part No SW: 4L0 920 985 Q HW: 4L0 920 985 Q Component: KOMBIINSTR. H35 0332 Revision: 00000000 Serial number: X2S02EV1G Coding: 8BD664040900CF05020205 Shop #: WSC 31414 790 00001 VCID: 428B5615DD95169B95-8016 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels:. 4F0-907-468.clb Part No SW: 4F0 907 468 S HW: 4F0 907 468 G Component: GW-BEM 5CAN-M H06 0058 Revision: MB800038 Serial number: 3800M151250664 Coding: 00C303 Shop #: WSC 31414 790 00001 VCID: 3F8D5FE1AE677B73FA-806A Subsystem 1 - Part No SW: 8K0 915 181 D HW: 8K0 915 181 D Component: J367-BDM H07 0125 Serial number: 42014N47244121322106 No fault code found. ------------------------------------------------------------------------------- Address 28: HVAC, Rear Labels: None Part No SW: 4L0 910 158 HW: 4L0 919 158 AE Component: KLIMABETAETIGUNGH06 0060 Revision: 00---011 Serial number: 00000030368670 Coding: 0000006 Shop #: WSC 31414 790 00001 VCID: 68DFA4BD5B691CCB6B-803C No fault code found. ------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr (J136) Labels: None Part No SW: 4F0 959 760 D HW: 4F0 959 760 D Component: MEM-FS H08 0065 Revision: AA000000 Serial number: 00000130217561 Coding: 00581B00000011110000 Shop #: WSC 31414 790 00001 VCID: 326B06D56D35A61B05-8066 No fault code found. ------------------------------------------------------------------------------- Address 3C: Lane Change Labels: None Part No SW: 4L0 910 566 C HW: 4L0 907 566 B Component: J0769_SWA_MasterH03 0050 Revision: 00H03000 Serial number: 6PZ 009 014-10 Coding: 0010001 Shop #: WSC 31414 790 00001 VCID: 2E5312A5B90D82FB61-807A Subsystem 1 - Part No: 4L0 910 568 C Component: J0770_SWA_Slave_H03 0050 Subsystem 2 - Serial number: 6PZ 009 014-30 Subsystem 3 - Serial number: 5F22.01.1500H03000AMS14246ÿ Subsystem 4 - Serial number: S14246ÿ No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver (J386) Labels:. 4F0-959-793.clb Part No SW: 4F0 959 793 T HW: 8K0 959 793 M Component: TSG FA H12 0362 Revision: Serial number: 0000134179191 Coding: 011F57205E40440004 Shop #: WSC 31414 790 00001 VCID: 489F443DFBA93CCB4B-801C No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels:. 4L0-910-289.lbl Part No SW: 4L0 910 289 K HW: 4L0 907 289 K Component: Komfortgeraet H12 0130 Revision: 0130 --- Serial number: 82009800020000 Coding: 3569949 Shop #: WSC 31414 790 00001 VCID: 387F34FD4B494C4B3B-806C Subsystem 1 - Part No: 1K0 951 605 C Component: LIN BACKUP HORN H05 1501 1 Fault Found: 00526 - Brake Light Switch (F) 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 3 Fault Frequency: 5 Reset counter: 28 Mileage: 63321 km Time Indication: 0 Date: 2021.04.11 Time: 13:04:20 ------------------------------------------------------------------------------- Address 47: Sound System (J525) Labels: None Part No SW: 4L0 035 223 J HW: 4L0 035 223 G Component: BOSE G3 Q7 H04 0160 Revision: CH004001 Serial number: 00000000067934 Coding: 030000 Shop #: WSC 31414 790 00001 VCID: 2959E1B940E3E5C3B4-807C No fault code found. ------------------------------------------------------------------------------- Address 4C: Tire Pressure II Labels: 4F0-910-274.clb Part No SW: 4F0 910 274 B HW: 4F0 907 274 Component: J793 RKA+ H04 0110 Revision: 00000519 Serial number: 00005191084064 Coding: 0758477 Shop #: WSC 31414 790 00001 VCID: 2345F391E2CF3F93FE-8076 3 Faults Found: 01679 - ABS Wheel Speed Signal; Front Left 012 - Electrical Fault in Circuit - MIL ON Freeze Frame: Fault Status: 11101100 Fault Priority: 3 Fault Frequency: 7 Reset counter: 245 Mileage: 63114 km Time Indication: 0 Date: 2021.04.11 Time: 11:08:01 Freeze Frame: Hex Value: 0x0000 Hex Value: 0x0000 Hex Value: 0x0007 Voltage: 14.60 V Temperature: 13.0°C (no units): 54.0 01680 - ABS Wheel Speed Signal; Front Right 012 - Electrical Fault in Circuit - Intermittent Freeze Frame: Fault Status: 00101100 Fault Priority: 3 Fault Frequency: 2 Reset counter: 29 Mileage: 63711 km Time Indication: 0 Date: 2021.04.11 Time: 17:21:29 Freeze Frame: Hex Value: 0x8000 Hex Value: 0x0000 Hex Value: 0x005F Voltage: 14.10 V Temperature: 18.0°C (no units): 112.0 01316 - ABS Control Module 013 - Check DTC Memory - Intermittent Freeze Frame: Fault Status: 00101101 Fault Priority: 3 Fault Frequency: 7 Reset counter: 39 Mileage: 63108 km Time Indication: 0 Date: 2021.04.11 Time: 09:52:31 Freeze Frame: Hex Value: 0x0000 Hex Value: 0x0000 Hex Value: 0x0001 Voltage: 11.10 V Temperature: 10.0°C (no units): 0.0 ------------------------------------------------------------------------------- Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl Part No SW: 4F0 910 280 HW: 4F0 907 280 D Component: ILM Beifahrer H16 0100 Revision: Serial number: 00000000210845 Coding: 0012001 Shop #: WSC 31414 790 00001 VCID: 5EB38265892D527B91-800A No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. (J387) Labels:. 4F0-959-792.clb Part No SW: 4F0 959 792 T HW: 8K0 959 792 M Component: TSG BF H12 0362 Revision: Serial number: 0000134188175 Coding: 011F57205E40440004 Shop #: WSC 31414 790 00001 VCID: 479D4701F6B733B342-8012 No fault code found. ------------------------------------------------------------------------------- Address 55: Headlight Range Labels: 4F0-910-357.lbl Part No SW: 4L0 910 357 B HW: 4L0 907 357 B Component: AFS 1 H01 0010 Revision: 00000001 Serial number: Coding: 0000031 Shop #: WSC 31414 790 00001 VCID: 2B551BB18A1FF7D346-807E Subsystem 1 - Part No: 7L6 941 329 A Component: AFS-Modul links H07 0004 Subsystem 2 - Part No: 7L6 941 329 A Component: AFS-Modul rechtsH07 0004 1 Fault Found: 01316 - ABS Control Module 013 - Check DTC Memory - Intermittent Freeze Frame: Fault Status: 00101101 Fault Priority: 2 Fault Frequency: 4 Reset counter: 254 Mileage: 65666 km Time Indication: 0 Date: 2021.05.14 Time: 13:03:37 ------------------------------------------------------------------------------- Address 56: Radio (R) Labels: Redir Fail! Part No SW: 4G0 035 082 G HW: 4G0 035 082 Component: Radio U SIRIU H66 0133 Revision: AB001007 Serial number: 156AZ0F8186611 Coding: 020007010000000000 Shop #: WSC 31414 790 00001 VCID: 2447F08D27C138AB87-8070 No fault code found. ------------------------------------------------------------------------------- Address 5F: Information Electr. (J794) Labels:. 4E0-035-6xx-5F.clb Part No SW: 4L2 035 746 G HW: 4L2 035 746 G Component: H-BNT-NA H42 0901 Revision: -------- Serial number: 513AT0F7509241 Coding: 180200060004E3EF510023456F632003140000000100000000 Shop #: WSC 31414 790 00001 VCID: 326B06D56D35A61B05-8066 Subsystem 1 - Part No: 8R0 060 884 CJ Component: NAR 2015 1102 Subsystem 2 - Part No SW: 8R0 919 604 A HW: 8R0 919 604 A Component: DU7 High H42 0104 Serial number: A130AQ0F3245664 Subsystem 3 - Part No SW: 4L0 919 614 C HW: 4L0 919 614 C Component: E0380 Bedient H01 0060 Serial number: 00000002226323 Subsystem 4 - Part No: 8R0 060 961 G Component: CD-Database 5950 No fault code found. ------------------------------------------------------------------------------- Address 62: Door, Rear Left (J388) Labels:. 4F0-959-795.clb Part No SW: 4F0 959 795 P HW: 4F0 959 795 P Component: TSG HL H11 0362 Revision: Serial number: 0000134983521 Coding: 010E57204040230004 Shop #: WSC 31414 790 00001 VCID: 46834A05F1BD2ABBB9-8012 No fault code found. ------------------------------------------------------------------------------- Address 69: Trailer (J345) Labels:. 4E0-907-383.clb Part No SW: 4E0 907 383 J HW: 4E0 907 383 J Component: Anhaenger H09 0100 Revision: 2A001001 Serial number: 00000358613333 Coding: 0200000000000000 Shop #: WSC 31414 790 00001 VCID: 316909D968339D037C-8064 1 Fault Found: 00526 - Brake Light Switch (F) 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 3 Fault Frequency: 1 Reset counter: 29 Mileage: 63367 km Time Indication: 0 Date: 2021.04.11 Time: 13:39:26 ------------------------------------------------------------------------------- Address 6C: Back-up Cam. (J928) Labels:* None Part No SW: 4L0 907 428 HW: 7P6 907 441 D Component: TopView H05 0293 Revision: 11001001 Serial number: 82330JF0199717 Coding: 020C010001000100010102000000 Shop #: WSC 31414 790 00001 ASAM Dataset: EV_CamSysteCorneViewAUDI 004005 ROD: EV_CamSysteCorneViewAUDI.rod VCID: 6ED3D2A5B18DC2FB21-803A No fault code found. ------------------------------------------------------------------------------- Address 6D: Trunk Elect. Labels: 4L0-910-945.clb Part No SW: 4L0 910 945 HW: 4L0 827 851 F Component: ValeoHeckdeckel H58 0500 Revision: --H58001 Serial number: E5030000B Shop #: WSC 98765 666 38354 VCID: 6CD7D8AD4F9130EB0F-8038 Subsystem 1 - Part No: 4L0 910 946 Component: ValeoHeckdeckel H58 0500 Subsystem 2 - Serial number: E5030100B Subsystem 3 - Serial number: RD26.01.15--H58001001B0183ÿ Subsystem 4 - Serial number: 1B0183ÿ No fault code found. ------------------------------------------------------------------------------- Address 6F: Centr. Conv. II Labels:. 4L0-910-290.lbl Part No SW: 4L0 910 290 A HW: 4L0 907 290 A Component: ILM HINTEN 2 H08 0080 Revision: AAH08080 Serial number: 0135020915---- Coding: 0003595 Shop #: WSC 31414 790 00001 VCID: 2643EA8591FDCABB99-8072 Subsystem 1 - Part No: 4L0 910 591 A Component: J_245_EE16_SKB10H15 0220 Subsystem 2 - Part No: 4L0 910 591 A Component: J_394_EE16_SKB10H15 0220 Subsystem 3 - Part No: 4L0 910 591 A Component: J_392_EE16_SKB10H15 0220 No fault code found. ------------------------------------------------------------------------------- Address 72: Door, Rear Right (J389) Labels:. 4F0-959-795.clb Part No SW: 4F0 959 795 P HW: 4F0 959 795 P Component: TSG HR H11 0362 Revision: Serial number: 0000134983315 Coding: 010E57204040230004 Shop #: WSC 31414 790 00001 VCID: 46834A05F1BD2ABBB9-8012 No fault code found. End-------------------------(Elapsed Time: 04:02)--------------------------
UPDATE 2:
I think I'm suspecting the battery. The voltage draws are low to modules, especially to the wheel speed sensor but someone with more knowledge can chime in? Here is the code after I waited a day and cleared the code the day before and drove for a few more miles and today did a rescan and here are the current fault codes:
Code:
Saturday,15,May,2021,11:13:12:06855 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64 VCDS Version: 21.3.0.0 (x64) Data version: 20210226 DS325.0 www.Ross-Tech.com VIN: WA1WMAFEXFD015639 License Plate: Chassis Type: FE-AU56 (4F0) Scan: 01 02 03 05 08 09 10 15 16 17 19 28 36 3C 42 46 47 4C 4F 52 55 56 5F 62 69 6C 6D 6F 72 VIN: WA1WMAFEXFD015639 Mileage: 65700km-40824miles 01-Engine -- Status: Malfunction 0010 02-Auto Trans -- Status: Malfunction 0010 03-ABS Brakes -- Status: Malfunction 0010 04-Steering Angle -- Status: OK 0000 05-Acc/Start Auth. -- Status: Malfunction 0010 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: OK 0000 10-Park/Steer Assist -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: Malfunction 0010 28-HVAC, Rear -- Status: OK 0000 36-Seat Mem. Drvr -- Status: OK 0000 3C-Lane Change -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 46-Central Conv. -- Status: OK 0000 47-Sound System -- Status: OK 0000 4C-Tire Pressure II -- Status: Malfunction 0010 4F-Centr. Electr. II -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 55-Headlight Range -- Status: OK 0000 56-Radio -- Status: OK 0000 5F-Information Electr. -- Status: OK 0000 62-Door, Rear Left -- Status: OK 0000 69-Trailer -- Status: OK 0000 6C-Back-up Cam. -- Status: OK 0000 6D-Trunk Elect. -- Status: OK 0000 6F-Centr. Conv. II -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine (J623-CNRB) Labels:. 059-907-401-V2.clb Part No SW: 4L2 910 401 A HW: 4L0 907 401 E Component: 3.0TDI EDC17 H23 0007 Revision: 54H23--- Serial number: Coding: 2A2A4012253600050000 Shop #: WSC 31414 790 00001 ASAM Dataset: EV_ECM30TDI0114L2910401A 001008 ROD: EV_ECM30TDI0114L2910401A.rod VCID: 224BF69535D5369BF5-8076 1 Fault Found: 4675 - Please Check Fault Codes in Control Module for ABS Brakes U1017 00 [036] - - [New feature! Extended UDS fault detail is only supported by current gen. interfaces] Intermittent - Not Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Mileage: 65701 km Date: 2021.05.14 Time: 22:17:45 Engine RPM: 1166.50 /min Normed load value: 23.5 % Vehicle speed: 33 km/h Coolant temperature: 69 °C Intake air temperature: 29 °C Ambient air pressure: 1010 mbar Voltage terminal 30: 13.900 V Unlearning counter according OBD: 40 Limitation: accelerator pedal: 51.3 Nm CAN status - engine control module-Bits 0-7: 0 Cruise Control System (CCS): status-Bits 0-7: 40 CAN status - transmission control module-Bits 0-7: 0 CAN status - brake control module 1-Bits 0-7: 0 CAN status - brake control module 2-Bits 0-7: 0 selected gear-Bits 0-7: 4 Readiness: 0 0 0 1 1 ------------------------------------------------------------------------------- Address 02: Auto Trans (J217) Labels:| 0C8-927-750.clb Part No SW: 0C8 927 750 AQ HW: 0C8 927 750 AQ Component: AL1000 AISIN 002 2454 Serial number: Coding: 001378 Shop #: WSC 03206 002 1048576 ASAM Dataset: EV_TCMAL991031 002114 ROD: EV_TCMAL991031_002.rod VCID: 7BF5EBF1F2FFA75396-802E 1 Fault Found: 12835 - Implausible Data Received from ABS Control Module U0415 00 [008] - - Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 3 Reset counter: 195 Mileage: 0 km Date: 2013.02.27 Time: 00:00:11 Engine RPM: 1140.0 /min Transmission input speed: 1140 /min Transmission output speed: 780 /min Engine torque: 12 Nm ATF temperature: 66 °C Accelerator pedal position: 6.4 % Clutch_C1: closed Clutch_C2: Open Clutch_C3: Open Clutch_C4: closed Clutch_B1: Open Clutch_B2: Open Lock Up Clutch: closed EOP target revolution: 65534 /min EOP actual revolution: 65279 /min Engine Speed signal Current: 65279 /min EOP failure status with EOP without HV 1: Motor normal stop EOP target current: 65278 mA ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels:. 4L0-910-517-V2.clb Part No SW: 4L0 910 517 M HW: 4L0 614 517 L Component: ESP ALLRAD MK25E1 0020 Revision: 00H02001 Coding: 0099441 Shop #: WSC 31414 790 00001 VCID: 346700CD5721A82B17-8060 2 Faults Found: 00290 - ABS Wheel Speed Sensor; Rear Left (G46) 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 2 Fault Frequency: 2 Reset counter: 254 Mileage: 65699 km Time Indication: 0 Date: 2021.05.14 Time: 21:52:39 Freeze Frame: Count: 320 Count: 8529 Count: 73 Count: 50688 00814 - Solenoid for Brake Pressure (N247) 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 01101100 Fault Priority: 2 Fault Frequency: 2 Reset counter: 254 Mileage: 65699 km Time Indication: 0 Freeze Frame: Count: 192 Count: 833 Count: 99 Count: 37888 ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. Labels:. 4F0-910-852.clb Part No SW: 4F0 910 852 B HW: 4F0 905 852 H Component: FBSAUDIC6 ELV H08 0210 Revision: 00H08000 Serial number: 10603902184301 Coding: 0000135 Shop #: WSC 31414 790 00001 VCID: 2541ED89ECFBC1A390-8070 Subsystem 1 - Part No: 4F0 910 132 L Component: FBSAUDIC6 EZS H05 0020 Subsystem 2 - Part No: 4F0 910 335 B Component: FBSAUDIC6 KSG H03 0020 Subsystem 3 - Part No: 4F0 910 220 G Component: FBSAUDIC6 IDG H01 0053 1 Fault Found: 00191 - Passenger's Door Handle Touch Sensor (G416) 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 3 Fault Frequency: 3 Reset counter: 38 Mileage: 65699 km Time Indication: 0 Date: 2021.05.14 Time: 21:06:24 ------------------------------------------------------------------------------- Address 08: Auto HVAC (J255) Labels: None Part No SW: 4L0 910 043 D HW: 4L0 820 043 AQ Component: KLIMA 4 ZONEN H15 0070 Revision: 00---031 Serial number: 00000000461021 Coding: 0304A036 Shop #: WSC 31414 790 00001 VCID: 2541ED892CFBC1A390-8070 Subsystem 1 - Part No SW: 8K0 959 772 F HW: 8K0 959 772 Component: SLR-B8 H06 0007 Serial number: 0132731213 Coding: 070000 Subsystem 2 - Part No SW: 8K0 959 772 F HW: 8K0 959 772 Component: SLR-B8 H06 0007 Serial number: 0132730159 Coding: 070000 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 4F0-910-279.lbl Part No SW: 4F0 910 279 AG HW: 4F0 907 279 C Component: ILM Fahrer H31 0400 Revision: 00000000 Serial number: 4F0907279 Coding: 0133123 Shop #: WSC 31414 790 00001 VCID: 6ED3D2A5798DC2FB21-803A Subsystem 1 - Part No: 4L1 910 113 Labels: 1KX-955-119.CLB Component: Wischer AU716 H18 0110 Coding: 00064792 Shop #: WSC 31414 Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB Component: REGENLICHTSENSORH04 0003 Coding: 00150059 Shop #: WSC 31414 No fault code found. ------------------------------------------------------------------------------- Address 10: Park/Steer Assist (J446) Labels:| 4L0-919-475-7X2.clb Part No SW: 4L0 919 475 A HW: 4H0 919 475 C Component: PARKHILFE 8K H07 0011 Revision: 11001001 Serial number: 55931501600240 Coding: 29011F Shop #: WSC 31414 790 00001 ASAM Dataset: EV_EPHVA18AU7160000 001001 ROD: EV_EPHVA18AU7160000.rod VCID: 346700CD9F21A82B17-8060 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: 4L0-910-655.lbl Part No SW: 4L0 910 655 A HW: 4L0 959 655 B Component: 73 AIRBAG AUDI8RH45 0230 Revision: 09H45000 Serial number: 0038QD90HCLN Coding: 0014131 Shop #: WSC 31414 790 00001 VCID: 2B551BB18A1FF7D346-807E Subsystem 1 - Part No: 4L0 959 339 C Component: BF-Gewichtsens. H05 0040 Subsystem 2 - Serial number: 6332QSME514C1462A Subsystem 3 - Serial number: 6342QSME544C4874O Subsystem 4 - Serial number: 6352QSME154D0E56P Subsystem 5 - Serial number: 6362QSME514C0948L Subsystem 6 - Serial number: 63734SME7C4B5358D Subsystem 7 - Serial number: 63834SME7C4B307CF No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 4F0-910-549.lbl Part No SW: 4F0 910 549 B HW: 4F0 953 549 E Component: J0527 0830 Revision: 00H09000 Serial number: 90026143570090 Coding: 0012142 Shop #: WSC 31414 790 00001 VCID: 285FE4BD9BE9DCCBAB-807C Subsystem 1 - Part No: XXXXXXXXXXX Component: E0221 H03 0040 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels:. 4L0-920-xxx-17.clb Part No SW: 4L0 920 985 Q HW: 4L0 920 985 Q Component: KOMBIINSTR. H35 0332 Revision: 00000000 Serial number: X2S02EV1G Coding: 8BD664040900CF05020205 Shop #: WSC 31414 790 00001 VCID: 428B5615DD95169B95-8016 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels:. 4F0-907-468.clb Part No SW: 4F0 907 468 S HW: 4F0 907 468 G Component: GW-BEM 5CAN-M H06 0058 Revision: MB800038 Serial number: 3800M151250664 Coding: 00C303 Shop #: WSC 31414 790 00001 VCID: 3F8D5FE1AE677B73FA-806A Subsystem 1 - Part No SW: 8K0 915 181 D HW: 8K0 915 181 D Component: J367-BDM H07 0125 Serial number: 42014N47244121322106 1 Fault Found: 02001 - Data-Bus Automatic Distance Regulation 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 1 Fault Frequency: 1 Reset counter: 39 Mileage: 65701 km Time Indication: 0 Date: 2021.05.14 Time: 23:10:58 Freeze Frame: Bin. Bits: 10111 Voltage: 11.70 V Count: 7 Bin. Bits: 10011 ------------------------------------------------------------------------------- Address 28: HVAC, Rear Labels: None Part No SW: 4L0 910 158 HW: 4L0 919 158 AE Component: KLIMABETAETIGUNGH06 0060 Revision: 00---011 Serial number: 00000030368670 Coding: 0000006 Shop #: WSC 31414 790 00001 VCID: 68DFA4BD5B691CCB6B-803C No fault code found. ------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr (J136) Labels: None Part No SW: 4F0 959 760 D HW: 4F0 959 760 D Component: MEM-FS H08 0065 Revision: AA000000 Serial number: 00000130217561 Coding: 00581B00000011110000 Shop #: WSC 31414 790 00001 VCID: 326B06D56D35A61B05-8066 No fault code found. ------------------------------------------------------------------------------- Address 3C: Lane Change Labels: None Part No SW: 4L0 910 566 C HW: 4L0 907 566 B Component: J0769_SWA_MasterH03 0050 Revision: 00H03000 Serial number: 6PZ 009 014-10 Coding: 0010001 Shop #: WSC 31414 790 00001 VCID: 2E5312A5B90D82FB61-807A Subsystem 1 - Part No: 4L0 910 568 C Component: J0770_SWA_Slave_H03 0050 Subsystem 2 - Serial number: 6PZ 009 014-30 Subsystem 3 - Serial number: 5F22.01.1500H03000AMS14246ÿ Subsystem 4 - Serial number: S14246ÿ No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver (J386) Labels:. 4F0-959-793.clb Part No SW: 4F0 959 793 T HW: 8K0 959 793 M Component: TSG FA H12 0362 Revision: Serial number: 0000134179191 Coding: 011F57205E40440004 Shop #: WSC 31414 790 00001 VCID: 489F443DFBA93CCB4B-801C No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels:. 4L0-910-289.lbl Part No SW: 4L0 910 289 K HW: 4L0 907 289 K Component: Komfortgeraet H12 0130 Revision: 0130 --- Serial number: 82009800020000 Coding: 3569949 Shop #: WSC 31414 790 00001 VCID: 387F34FD4B494C4B3B-806C Subsystem 1 - Part No: 1K0 951 605 C Component: LIN BACKUP HORN H05 1501 No fault code found. ------------------------------------------------------------------------------- Address 47: Sound System (J525) Labels: None Part No SW: 4L0 035 223 J HW: 4L0 035 223 G Component: BOSE G3 Q7 H04 0160 Revision: CH004001 Serial number: 00000000067934 Coding: 030000 Shop #: WSC 31414 790 00001 VCID: 2959E1B940E3E5C3B4-807C No fault code found. ------------------------------------------------------------------------------- Address 4C: Tire Pressure II Labels: 4F0-910-274.clb Part No SW: 4F0 910 274 B HW: 4F0 907 274 Component: J793 RKA+ H04 0110 Revision: 00000519 Serial number: 00005191084064 Coding: 0758477 Shop #: WSC 31414 790 00001 VCID: 2345F391E2CF3F93FE-8076 2 Faults Found: 01679 - ABS Wheel Speed Signal; Front Left 012 - Electrical Fault in Circuit - MIL ON Freeze Frame: Fault Status: 11101100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 254 Mileage: 65700 km Time Indication: 0 Date: 2021.05.14 Time: 22:15:23 Freeze Frame: Hex Value: 0x0000 Hex Value: 0x0000 Hex Value: 0x0007 Voltage: 13.70 V Temperature: 25.0°C (no units): 45.0 01316 - ABS Control Module 013 - Check DTC Memory - MIL ON Freeze Frame: Fault Status: 11101101 Fault Priority: 3 Fault Frequency: 3 Reset counter: 254 Mileage: 65699 km Time Indication: 0 Date: 2021.05.14 Time: 21:38:21 Freeze Frame: Hex Value: 0x0000 Hex Value: 0x0000 Hex Value: 0x0005 Voltage: 11.90 V Temperature: 25.0°C (no units): 0.0 ------------------------------------------------------------------------------- Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl Part No SW: 4F0 910 280 HW: 4F0 907 280 D Component: ILM Beifahrer H16 0100 Revision: Serial number: 00000000210845 Coding: 0012001 Shop #: WSC 31414 790 00001 VCID: 5EB38265892D527B91-800A No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. (J387) Labels:. 4F0-959-792.clb Part No SW: 4F0 959 792 T HW: 8K0 959 792 M Component: TSG BF H12 0362 Revision: Serial number: 0000134188175 Coding: 011F57205E40440004 Shop #: WSC 31414 790 00001 VCID: 479D4701F6B733B342-8012 No fault code found. ------------------------------------------------------------------------------- Address 55: Headlight Range Labels: 4F0-910-357.lbl Part No SW: 4L0 910 357 B HW: 4L0 907 357 B Component: AFS 1 H01 0010 Revision: 00000001 Serial number: Coding: 0000031 Shop #: WSC 31414 790 00001 VCID: 2B551BB18A1FF7D346-807E Subsystem 1 - Part No: 7L6 941 329 A Component: AFS-Modul links H07 0004 Subsystem 2 - Part No: 7L6 941 329 A Component: AFS-Modul rechtsH07 0004 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio (R) Labels: Redir Fail! Part No SW: 4G0 035 082 G HW: 4G0 035 082 Component: Radio U SIRIU H66 0133 Revision: AB001007 Serial number: 156AZ0F8186611 Coding: 020007010000000000 Shop #: WSC 31414 790 00001 VCID: 2447F08D27C138AB87-8070 No fault code found. ------------------------------------------------------------------------------- Address 5F: Information Electr. (J794) Labels:. 4E0-035-6xx-5F.clb Part No SW: 4L2 035 746 G HW: 4L2 035 746 G Component: H-BNT-NA H42 0901 Revision: -------- Serial number: 513AT0F7509241 Coding: 180200060004E3EF510023456F632003140000000100000000 Shop #: WSC 31414 790 00001 VCID: 326B06D56D35A61B05-8066 Subsystem 1 - Part No: 8R0 060 884 CJ Component: NAR 2015 1102 Subsystem 2 - Part No SW: 8R0 919 604 A HW: 8R0 919 604 A Component: DU7 High H42 0104 Serial number: A130AQ0F3245664 Subsystem 3 - Part No SW: 4L0 919 614 C HW: 4L0 919 614 C Component: E0380 Bedient H01 0060 Serial number: 00000002226323 Subsystem 4 - Part No: 8R0 060 961 G Component: CD-Database 5950 No fault code found. ------------------------------------------------------------------------------- Address 62: Door, Rear Left (J388) Labels:. 4F0-959-795.clb Part No SW: 4F0 959 795 P HW: 4F0 959 795 P Component: TSG HL H11 0362 Revision: Serial number: 0000134983521 Coding: 010E57204040230004 Shop #: WSC 31414 790 00001 VCID: 46834A05F1BD2ABBB9-8012 No fault code found. ------------------------------------------------------------------------------- Address 69: Trailer (J345) Labels:. 4E0-907-383.clb Part No SW: 4E0 907 383 J HW: 4E0 907 383 J Component: Anhaenger H09 0100 Revision: 2A001001 Serial number: 00000358613333 Coding: 0200000000000000 Shop #: WSC 31414 790 00001 VCID: 316909D968339D037C-8064 No fault code found. ------------------------------------------------------------------------------- Address 6C: Back-up Cam. (J928) Labels:* None Part No SW: 4L0 907 428 HW: 7P6 907 441 D Component: TopView H05 0293 Revision: 11001001 Serial number: 82330JF0199717 Coding: 020C010001000100010102000000 Shop #: WSC 31414 790 00001 ASAM Dataset: EV_CamSysteCorneViewAUDI 004005 ROD: EV_CamSysteCorneViewAUDI.rod VCID: 6ED3D2A5B18DC2FB21-803A No fault code found. ------------------------------------------------------------------------------- Address 6D: Trunk Elect. Labels: 4L0-910-945.clb Part No SW: 4L0 910 945 HW: 4L0 827 851 F Component: ValeoHeckdeckel H58 0500 Revision: --H58001 Serial number: E5030000B Shop #: WSC 98765 666 38354 VCID: 6CD7D8AD4F9130EB0F-8038 Subsystem 1 - Part No: 4L0 910 946 Component: ValeoHeckdeckel H58 0500 Subsystem 2 - Serial number: E5030100B Subsystem 3 - Serial number: RD26.01.15--H58001001B0183ÿ Subsystem 4 - Serial number: 1B0183ÿ No fault code found. ------------------------------------------------------------------------------- Address 6F: Centr. Conv. II Labels:. 4L0-910-290.lbl Part No SW: 4L0 910 290 A HW: 4L0 907 290 A Component: ILM HINTEN 2 H08 0080 Revision: AAH08080 Serial number: 0135020915---- Coding: 0003595 Shop #: WSC 31414 790 00001 VCID: 2643EA8591FDCABB99-8072 Subsystem 1 - Part No: 4L0 910 591 A Component: J_245_EE16_SKB10H15 0220 Subsystem 2 - Part No: 4L0 910 591 A Component: J_394_EE16_SKB10H15 0220 Subsystem 3 - Part No: 4L0 910 591 A Component: J_392_EE16_SKB10H15 0220 No fault code found. ------------------------------------------------------------------------------- Address 72: Door, Rear Right (J389) Labels:. 4F0-959-795.clb Part No SW: 4F0 959 795 P HW: 4F0 959 795 P Component: TSG HR H11 0362 Revision: Serial number: 0000134983315 Coding: 010E57204040230004 Shop #: WSC 31414 790 00001 VCID: 46834A05F1BD2ABBB9-8012 No fault code found. End-------------------------(Elapsed Time: 04:05)--------------------------
Club AutoUnion
Ended up taking the vehicle to the dealer. I ended up ordering a diagnostic service so they could rule it out. They diagnosed the issue to be a wheel speed sensor on the rear left that they replaced as indicated on the second scan.
I performed a second scan as soon as I got back and this is the scan:
The technician noted that as he test drove it, it produced another "new" code related to the solenoid brake booster which as indicated on previous scans was already shown. He noted that the TPMS light is on due to this. I am very pleased to know that all other codes are gone from the scan. Unfortunately the TPMS and ESC lights remain on. I told them that I was on trip so they advised to have it checked out when I got back from trip. The vehicle is safe to drive (took a big risk to even drive...) They couldn't fix the sensor for that part as they did not have it in stock and I had to leave in a day or two anyways. So this is the inspection sheet and the comments from the technician:
Is that code for the wheel speed sensor that is still showing an issue from the brake booster sensor? I also don't know which brake booster sensor it is or where it is located from which tire location or is this just one thing that is in the engine bay?
Code:
Saturday,15,May,2021,16:34:25:06855 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64 VCDS Version: 21.3.0.0 (x64) Data version: 20210226 DS325.0 www.Ross-Tech.com VIN: WA1WMAFEXFD015639 License Plate: Chassis Type: FE-AU56 (4F0) Scan: 01 02 03 05 08 09 10 15 16 17 19 28 36 3C 42 46 47 4C 4F 52 55 56 5F 62 69 6C 6D 6F 72 VIN: WA1WMAFEXFD015639 Mileage: 65760km-40861miles 01-Engine -- Status: OK 0000 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: Malfunction 0010 04-Steering Angle -- Status: OK 0000 05-Acc/Start Auth. -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: OK 0000 10-Park/Steer Assist -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 28-HVAC, Rear -- Status: OK 0000 36-Seat Mem. Drvr -- Status: OK 0000 3C-Lane Change -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 46-Central Conv. -- Status: OK 0000 47-Sound System -- Status: OK 0000 4C-Tire Pressure II -- Status: Malfunction 0010 4F-Centr. Electr. II -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 55-Headlight Range -- Status: OK 0000 56-Radio -- Status: OK 0000 5F-Information Electr. -- Status: OK 0000 62-Door, Rear Left -- Status: OK 0000 69-Trailer -- Status: OK 0000 6C-Back-up Cam. -- Status: OK 0000 6D-Trunk Elect. -- Status: OK 0000 6F-Centr. Conv. II -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine (J623-CNRB) Labels:. 059-907-401-V2.clb Part No SW: 4L2 910 401 A HW: 4L0 907 401 E Component: 3.0TDI EDC17 H23 0007 Revision: 54H23--- Serial number: Coding: 2A2A4012253600050000 Shop #: WSC 31414 790 00001 ASAM Dataset: EV_ECM30TDI0114L2910401A 001008 ROD: EV_ECM30TDI0114L2910401A.rod VCID: 224BF69535D5369BF5-8076 No fault code found. Readiness: 0 0 0 0 0 ------------------------------------------------------------------------------- Address 02: Auto Trans (J217) Labels:| 0C8-927-750.clb Part No SW: 0C8 927 750 AQ HW: 0C8 927 750 AQ Component: AL1000 AISIN 002 2454 Serial number: Coding: 001378 Shop #: WSC 03206 002 1048576 ASAM Dataset: EV_TCMAL991031 002114 ROD: EV_TCMAL991031_002.rod VCID: 7BF5EBF1F2FFA75396-802E No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels:. 4L0-910-517-V2.clb Part No SW: 4L0 910 517 M HW: 4L0 614 517 L Component: ESP ALLRAD MK25E1 0020 Revision: 00H02001 Coding: 0099441 Shop #: WSC 31414 790 00001 VCID: 346700CD5721A82B17-8060 1 Fault Found: 00814 - Solenoid for Brake Pressure (N247) 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 01101100 Fault Priority: 2 Fault Frequency: 2 Reset counter: 0 Mileage: 65738 km Time Indication: 0 Freeze Frame: Count: 128 Count: 833 Count: 99 Count: 45312 ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. Labels:. 4F0-910-852.clb Part No SW: 4F0 910 852 B HW: 4F0 905 852 H Component: FBSAUDIC6 ELV H08 0210 Revision: 00H08000 Serial number: 10603902184301 Coding: 0000135 Shop #: WSC 31414 790 00001 VCID: 2541ED89ECFBC1A390-8070 Subsystem 1 - Part No: 4F0 910 132 L Component: FBSAUDIC6 EZS H05 0020 Subsystem 2 - Part No: 4F0 910 335 B Component: FBSAUDIC6 KSG H03 0020 Subsystem 3 - Part No: 4F0 910 220 G Component: FBSAUDIC6 IDG H01 0053 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC (J255) Labels: None Part No SW: 4L0 910 043 D HW: 4L0 820 043 AQ Component: KLIMA 4 ZONEN H15 0070 Revision: 00---031 Serial number: 00000000461021 Coding: 0304A036 Shop #: WSC 31414 790 00001 VCID: 2541ED892CFBC1A390-8070 Subsystem 1 - Part No SW: 8K0 959 772 F HW: 8K0 959 772 Component: SLR-B8 H06 0007 Serial number: 0132731213 Coding: 070000 Subsystem 2 - Part No SW: 8K0 959 772 F HW: 8K0 959 772 Component: SLR-B8 H06 0007 Serial number: 0132730159 Coding: 070000 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 4F0-910-279.lbl Part No SW: 4F0 910 279 AG HW: 4F0 907 279 C Component: ILM Fahrer H31 0400 Revision: 00000000 Serial number: 4F0907279 Coding: 0133123 Shop #: WSC 31414 790 00001 VCID: 6ED3D2A5798DC2FB21-803A Subsystem 1 - Part No: 4L1 910 113 Labels: 1KX-955-119.CLB Component: Wischer AU716 H18 0110 Coding: 00064792 Shop #: WSC 31414 Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB Component: REGENLICHTSENSORH04 0003 Coding: 00150059 Shop #: WSC 31414 No fault code found. ------------------------------------------------------------------------------- Address 10: Park/Steer Assist (J446) Labels:| 4L0-919-475-7X2.clb Part No SW: 4L0 919 475 A HW: 4H0 919 475 C Component: PARKHILFE 8K H07 0011 Revision: 11001001 Serial number: 55931501600240 Coding: 29011F Shop #: WSC 31414 790 00001 ASAM Dataset: EV_EPHVA18AU7160000 001001 ROD: EV_EPHVA18AU7160000.rod VCID: 346700CD9F21A82B17-8060 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: 4L0-910-655.lbl Part No SW: 4L0 910 655 A HW: 4L0 959 655 B Component: 73 AIRBAG AUDI8RH45 0230 Revision: 09H45000 Serial number: 0038QD90HCLN Coding: 0014131 Shop #: WSC 31414 790 00001 VCID: 2B551BB18A1FF7D346-807E Subsystem 1 - Part No: 4L0 959 339 C Component: BF-Gewichtsens. H05 0040 Subsystem 2 - Serial number: 6332QSME514C1462A Subsystem 3 - Serial number: 6342QSME544C4874O Subsystem 4 - Serial number: 6352QSME154D0E56P Subsystem 5 - Serial number: 6362QSME514C0948L Subsystem 6 - Serial number: 63734SME7C4B5358D Subsystem 7 - Serial number: 63834SME7C4B307CF No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 4F0-910-549.lbl Part No SW: 4F0 910 549 B HW: 4F0 953 549 E Component: J0527 0830 Revision: 00H09000 Serial number: 90026143570090 Coding: 0012142 Shop #: WSC 31414 790 00001 VCID: 285FE4BD9BE9DCCBAB-807C Subsystem 1 - Part No: XXXXXXXXXXX Component: E0221 H03 0040 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels:. 4L0-920-xxx-17.clb Part No SW: 4L0 920 985 Q HW: 4L0 920 985 Q Component: KOMBIINSTR. H35 0332 Revision: 00000000 Serial number: X2S02EV1G Coding: 8BD664040900CF05020205 Shop #: WSC 31414 790 00001 VCID: 428B5615DD95169B95-8016 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels:. 4F0-907-468.clb Part No SW: 4F0 907 468 S HW: 4F0 907 468 G Component: GW-BEM 5CAN-M H06 0058 Revision: MB800038 Serial number: 3800M151250664 Coding: 00C303 Shop #: WSC 31414 790 00001 VCID: 3F8D5FE1AE677B73FA-806A Subsystem 1 - Part No SW: 8K0 915 181 D HW: 8K0 915 181 D Component: J367-BDM H07 0125 Serial number: 42014N47244121322106 No fault code found. ------------------------------------------------------------------------------- Address 28: HVAC, Rear Labels: None Part No SW: 4L0 910 158 HW: 4L0 919 158 AE Component: KLIMABETAETIGUNGH06 0060 Revision: 00---011 Serial number: 00000030368670 Coding: 0000006 Shop #: WSC 31414 790 00001 VCID: 68DFA4BD5B691CCB6B-803C No fault code found. ------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr (J136) Labels: None Part No SW: 4F0 959 760 D HW: 4F0 959 760 D Component: MEM-FS H08 0065 Revision: AA000000 Serial number: 00000130217561 Coding: 00581B00000011110000 Shop #: WSC 31414 790 00001 VCID: 326B06D56D35A61B05-8066 No fault code found. ------------------------------------------------------------------------------- Address 3C: Lane Change Labels: None Part No SW: 4L0 910 566 C HW: 4L0 907 566 B Component: J0769_SWA_MasterH03 0050 Revision: 00H03000 Serial number: 6PZ 009 014-10 Coding: 0010001 Shop #: WSC 31414 790 00001 VCID: 2E5312A5B90D82FB61-807A Subsystem 1 - Part No: 4L0 910 568 C Component: J0770_SWA_Slave_H03 0050 Subsystem 2 - Serial number: 6PZ 009 014-30 Subsystem 3 - Serial number: 5F22.01.1500H03000AMS14246ÿ Subsystem 4 - Serial number: S14246ÿ No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver (J386) Labels:. 4F0-959-793.clb Part No SW: 4F0 959 793 T HW: 8K0 959 793 M Component: TSG FA H12 0362 Revision: Serial number: 0000134179191 Coding: 011F57205E40440004 Shop #: WSC 31414 790 00001 VCID: 489F443DFBA93CCB4B-801C No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels:. 4L0-910-289.lbl Part No SW: 4L0 910 289 K HW: 4L0 907 289 K Component: Komfortgeraet H12 0130 Revision: 0130 --- Serial number: 82009800020000 Coding: 3569949 Shop #: WSC 31414 790 00001 VCID: 387F34FD4B494C4B3B-806C Subsystem 1 - Part No: 1K0 951 605 C Component: LIN BACKUP HORN H05 1501 No fault code found. ------------------------------------------------------------------------------- Address 47: Sound System (J525) Labels: None Part No SW: 4L0 035 223 J HW: 4L0 035 223 G Component: BOSE G3 Q7 H04 0160 Revision: CH004001 Serial number: 00000000067934 Coding: 030000 Shop #: WSC 31414 790 00001 VCID: 2959E1B940E3E5C3B4-807C No fault code found. ------------------------------------------------------------------------------- Address 4C: Tire Pressure II Labels: 4F0-910-274.clb Part No SW: 4F0 910 274 B HW: 4F0 907 274 Component: J793 RKA+ H04 0110 Revision: 00000519 Serial number: 00005191084064 Coding: 0758477 Shop #: WSC 31414 790 00001 VCID: 2345F391E2CF3F93FE-8076 2 Faults Found: 01679 - ABS Wheel Speed Signal; Front Left 012 - Electrical Fault in Circuit - MIL ON Freeze Frame: Fault Status: 11101100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 254 Mileage: 65739 km Time Indication: 0 Date: 2021.05.15 Time: 15:59:41 Freeze Frame: Hex Value: 0x0000 Hex Value: 0x0000 Hex Value: 0x0007 Voltage: 14.00 V Temperature: 25.0°C (no units): 60.0 01316 - ABS Control Module 013 - Check DTC Memory - Intermittent Freeze Frame: Fault Status: 00101101 Fault Priority: 3 Fault Frequency: 1 Reset counter: 39 Mileage: 65738 km Time Indication: 0 Date: 2021.05.15 Time: 15:45:17 Freeze Frame: Hex Value: 0x0000 Hex Value: 0x0000 Hex Value: 0x0005 Voltage: 12.20 V Temperature: 25.0°C (no units): 0.0 ------------------------------------------------------------------------------- Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl Part No SW: 4F0 910 280 HW: 4F0 907 280 D Component: ILM Beifahrer H16 0100 Revision: Serial number: 00000000210845 Coding: 0012001 Shop #: WSC 31414 790 00001 VCID: 5EB38265892D527B91-800A No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. (J387) Labels:. 4F0-959-792.clb Part No SW: 4F0 959 792 T HW: 8K0 959 792 M Component: TSG BF H12 0362 Revision: Serial number: 0000134188175 Coding: 011F57205E40440004 Shop #: WSC 31414 790 00001 VCID: 479D4701F6B733B342-8012 No fault code found. ------------------------------------------------------------------------------- Address 55: Headlight Range Labels: 4F0-910-357.lbl Part No SW: 4L0 910 357 B HW: 4L0 907 357 B Component: AFS 1 H01 0010 Revision: 00000001 Serial number: Coding: 0000031 Shop #: WSC 31414 790 00001 VCID: 2B551BB18A1FF7D346-807E Subsystem 1 - Part No: 7L6 941 329 A Component: AFS-Modul links H07 0004 Subsystem 2 - Part No: 7L6 941 329 A Component: AFS-Modul rechtsH07 0004 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio (R) Labels: Redir Fail! Part No SW: 4G0 035 082 G HW: 4G0 035 082 Component: Radio U SIRIU H66 0133 Revision: AB001007 Serial number: 156AZ0F8186611 Coding: 020007010000000000 Shop #: WSC 31414 790 00001 VCID: 2447F08D27C138AB87-8070 No fault code found. ------------------------------------------------------------------------------- Address 5F: Information Electr. (J794) Labels:. 4E0-035-6xx-5F.clb Part No SW: 4L2 035 746 G HW: 4L2 035 746 G Component: H-BNT-NA H42 0901 Revision: -------- Serial number: 513AT0F7509241 Coding: 180200060004E3EF510023456F632003140000000100000000 Shop #: WSC 31414 790 00001 VCID: 326B06D56D35A61B05-8066 Subsystem 1 - Part No: 8R0 060 884 CJ Component: NAR 2015 1102 Subsystem 2 - Part No SW: 8R0 919 604 A HW: 8R0 919 604 A Component: DU7 High H42 0104 Serial number: A130AQ0F3245664 Subsystem 3 - Part No SW: 4L0 919 614 C HW: 4L0 919 614 C Component: E0380 Bedient H01 0060 Serial number: 00000002226323 Subsystem 4 - Part No: 8R0 060 961 G Component: CD-Database 5950 No fault code found. ------------------------------------------------------------------------------- Address 62: Door, Rear Left (J388) Labels:. 4F0-959-795.clb Part No SW: 4F0 959 795 P HW: 4F0 959 795 P Component: TSG HL H11 0362 Revision: Serial number: 0000134983521 Coding: 010E57204040230004 Shop #: WSC 31414 790 00001 VCID: 46834A05F1BD2ABBB9-8012 No fault code found. ------------------------------------------------------------------------------- Address 69: Trailer (J345) Labels:. 4E0-907-383.clb Part No SW: 4E0 907 383 J HW: 4E0 907 383 J Component: Anhaenger H09 0100 Revision: 2A001001 Serial number: 00000358613333 Coding: 0200000000000000 Shop #: WSC 31414 790 00001 VCID: 316909D968339D037C-8064 No fault code found. ------------------------------------------------------------------------------- Address 6C: Back-up Cam. (J928) Labels:* None Part No SW: 4L0 907 428 HW: 7P6 907 441 D Component: TopView H05 0293 Revision: 11001001 Serial number: 82330JF0199717 Coding: 020C010001000100010102000000 Shop #: WSC 31414 790 00001 ASAM Dataset: EV_CamSysteCorneViewAUDI 004005 ROD: EV_CamSysteCorneViewAUDI.rod VCID: 6ED3D2A5B18DC2FB21-803A No fault code found. ------------------------------------------------------------------------------- Address 6D: Trunk Elect. Labels: 4L0-910-945.clb Part No SW: 4L0 910 945 HW: 4L0 827 851 F Component: ValeoHeckdeckel H58 0500 Revision: --H58001 Serial number: E5030000B Shop #: WSC 98765 666 38354 VCID: 6CD7D8AD4F9130EB0F-8038 Subsystem 1 - Part No: 4L0 910 946 Component: ValeoHeckdeckel H58 0500 Subsystem 2 - Serial number: E5030100B Subsystem 3 - Serial number: RD26.01.15--H58001001B0183ÿ Subsystem 4 - Serial number: 1B0183ÿ No fault code found. ------------------------------------------------------------------------------- Address 6F: Centr. Conv. II Labels:. 4L0-910-290.lbl Part No SW: 4L0 910 290 A HW: 4L0 907 290 A Component: ILM HINTEN 2 H08 0080 Revision: AAH08080 Serial number: 0135020915---- Coding: 0003595 Shop #: WSC 31414 790 00001 VCID: 2643EA8591FDCABB99-8072 Subsystem 1 - Part No: 4L0 910 591 A Component: J_245_EE16_SKB10H15 0220 Subsystem 2 - Part No: 4L0 910 591 A Component: J_394_EE16_SKB10H15 0220 Subsystem 3 - Part No: 4L0 910 591 A Component: J_392_EE16_SKB10H15 0220 No fault code found. ------------------------------------------------------------------------------- Address 72: Door, Rear Right (J389) Labels:. 4F0-959-795.clb Part No SW: 4F0 959 795 P HW: 4F0 959 795 P Component: TSG HR H11 0362 Revision: Serial number: 0000134983315 Coding: 010E57204040230004 Shop #: WSC 31414 790 00001 VCID: 46834A05F1BD2ABBB9-8012 No fault code found. End-------------------------(Elapsed Time: 04:05)--------------------------
Did you ever manage to solve this issue? I have the EXACT same issue. Had car on battery charger after battery went low and now I have those exact lights on my dash. Still figuring it out.
