2013 Q7 Running Boards
#12
Those running boards look great! I'm also eyeing a Romik black powder coat running board for my '14 Q7 but the fitment notes point out that it doesn't fit S Line models. Does anyone know why that is?
#13
Can you take a picture of underneath? I don't have S-line, but I am curious why S-line is different for many things? For example, I have installed splash guards. They don't fit S-line either.
#14
Will do, treasureking, once I get back home this weekend. It's a prestige model, so I wonder if that makes any difference? I'll post the pics once I get the chance.
#15
Added 2" extender
I think the running boards themselves are too much under the car. I can barely put my feet on it. Ordered the 2" extender and installed them. The process should be easy but something happened. One new bolt was messed up with the nut. I guess the nylon thread got damaged somehow in the middle. I had no choice but to cut the bolt off. Man! It took me quite a while. The bolt was so tough, hard steel. Anyway, I fixed it. Here is the picture. You may notice it sticks out a little bit, but it actually feels much better.
#16
#17
I am so confused as to why side mounted running boards would in any way interfere with the factory tow package (or an aftermarket receiver for that matter). Does anyone have the factory running boards that could take a few pictures?
#18
4L0092101C is oem tow hitch parts number
4L0017065, 4L0017066 are oem right and left running boards parts numbers
There is no way they use same points to bolt on the frame if you look at the pictures of them.
You can easily find pictures and installation manuals from google.
Mine has factory fitted tow hitch, and I installed oem knock off running boards from eBay, they even comes with oem running boards install instructions, by myself.
You will need to replace your jack with scissor type jack to lift the Q though.
#20
