2014 Q7 Carista Modification List
Searched and didn't see it posted anywhere for Q7s, so just in case anyone is considering purchasing the Carista dongle + app (instead of a VCDS cable), here's a list of the available 2014 Q7 modifications - at least for a Prestige S-Line:
Doors / Windows / Remote
Blink turn signals when locking doors
*YES* / NO
Blink turn signals when unlocking doors
*YES* / NO
Beep when alarm is armed
*YES* / NO
Unlock doors via remote
*DRIVER'S DOOR ON 1ST PRESS, ALL ON 2ND* / ALL DOORS ON 1ST PRESS
Enable settings for opening/closing windows and sunroof
*YES* / NO
Close windows via long-press on remote
*YES* / NO
Open windows via long-press on remote
*YES* / NO
Close sunroof via long-press on remote
YES / *NO*
Open sunroof via long-press on remote
*YES* / NO
Close windows by holding key in door lock
YES / *NO*
Close sunroof by holding key in door lock
YES / *NO*
Delay alarm activation
YES / *NO*
Instruments / Display / Dings
Hidden menu in dash screen via holding CAR + SETUP (req. restart)
*ENABLED* / DISABLED
Voice recognition
Display warning about using navigation when moving
YES / *NO*
Gauge needle sweep at startup
*YES* / NO
Gauge needles lit even when headlights are off
*YES* / NO
Gauge scales lit even when headlights are off
*YES* / NO
Seat belt warning
*DISABLED* / US/CANADA STYLE / EURO STYLE 1 / EURO STYLE 2 / EURO STYLE 3
Lap timer and oil temperature in dashboard
Navigation disc eject button
Lights
Daytime running lights
ENABLED / *ENABLED AND CONFIGURABLE IN MMI* / DISABLED
Lighting configuration region
OTHER / NORTHERN EUROPEAN COUNTRIES / *USA* / CANADA
Allow configuring footwell lights
Flash brake lights in emergency stopping
*YES* / NO
In addition, you can view any diagnostic codes and/or reset the service interval setting.
*YES* / NO
*YES* / NO
*YES* / NO
*YES* / NO
*YES* / NO
*YES* / NO
YES / *NO*
*YES* / NO
YES / *NO*
YES / *NO*
YES / *NO*
Voice recognition
YES / *NO*
*YES* / NO
*YES* / NO
*YES* / NO
Seat belt warning
Lights
*YES* / NO
Great app. Everything works on my 2008 except the needle sweep doesn't work on 2007 and 2008 US models. Only 2009+ I believe. Does anyone know if it works with vagcom? I also used Carista to switch my region to Northern European, now my tail lights are on with my DRLs.. I believe all cars should have front and rear DRLs. Why does the nhtsa not require this?
So, just curious why you configured this way? Oversight, or a reason to avoid this that I'm missing?
That's odd that you haven't set the sunroof to close with remote, but you do have it set to open. Being able to close the roof from afar if there's unexpected rain or an errant lawn sprinkler throwing water on your Q7 is very handy. Even if you promise you're self "I'll never leave it open", it just takes that one time to get you interior soaked and dry you MMI.
