21" Continental DSW
#11
235/60/18 is same OD as 295/35/21, set of Blizzack light truck are $650.. and holy crap, 21in snow tires are $1000-1400.. and thats without install.
I'm riding on 245/65/17, not 18s tho.. but generally for pure winter performance thinner tires are better as it increases contact weight and you can cut through slush/snow to solid ground for better traction.. for sand/mud that can just get you stuck worse tho.
#12
half an inch larger (1/4in lift), but only 0.3"in wider than 235.. I like to keep OD as close to stock as possible because you cant really carry a larger spare tire with that inflatable.. running a spare tire half an inch smaller would be bad on the drivetrain.. and having to do any distance on a spare tire in the winter would suck enough as is, why add to my stress eh?
If I was buying winter tires for 18's I'd start off with 235/60/18.. another nice thing about keeping OE OD is the fender arches look right.. the gap between the tire and fender is consistent all the way across the arch.. your speedo/odo also stay the same.
#14
then again, I was comparing to 21in OEM tire sizes.. 20in OEM tires seem to be a bit bigger 29.7in.. so mebe 245 would be be better if you were coming off 20's.. I have no idea if they give you a different size spare w/21in wheels.. probably not so I would just expect it to be made to match largest OD.. a half inch is going to be hard to notice either way, but if you want consistency in look and speed settings then I just find the closest size to the ones I'm taking off.. especially if your swapping between em twice a year.
I generally play with tire sizes and ignore OEM suggestions, you can often get better tires at better prices.. if half an inch larger saves me a couple hundred then half an inch larger it is, sometimes just going a bit thinner/thicker/bigger/smaller puts you in a more common size with dozens more choices to pick from.. this is a good resource: https://tiresize.com/calculator/
#16
What conditions are you typically on in the winter? Icy requires studs, Snow/Slush wants some meaty tread.. if your Snow/Slush on occasion and have mild temp winters or travel from mild winter to Snow/Slush then All Terrains (w/Snow ratings) are much longer lasting than performance snow, but if it stays below 50F all winter snows are better as the'll stay softer for icy conditions, and if your roads stay mostly snow covered all winter just get studded snow tires.. Here in Colorado what Altitude you lived at would determine what was most appropriate, and I'm seeing a more and more Audi's on steelies every day, ski season is just kicking off and looks like were all ready for battle.
#17
Sorry to hijack here but can anyone recommend the proper size winter tires that would be equivalent to 20" -- > 18" wheels? I.e. I want to downsize from 20" but keep the same height as us suggested above. Looking to maybe stay with the 18" if the ride quality improves significantly recognizing that the actual tires have a bearing on that too of course.
#18
245/60/18 are 0.1in larger OD than OEM 20in size tires.. its as close as you'll get
235/60/18 are exactly the same OD as OEM 21in size tires
both would be suitable regardless and are pretty much within OEM variance.. but when swapping winters/summers there are benefits to keeping the OD close as stated before..
I think I must have alot more miles under my belt than most people, Ive had lots of flat tires over the years.. might be the 8-10k mile tours I go on every couple years, Ive crossed a desert w/out a spare and lost before.. not something I'll let happen again.
#19
#20
