Amber Alert!!!
Amber Alert!!!
So I had the Amber ENGINE light pop on.
I ran a scan to see whats up, posted below.
I was away and the car sat from Feb. 28 until April 7, in which I understand things can happen, like the brakes seized on it, but didn't expect this much. But I figure this is the cause to such codes.
I have not ran a scan since March 2018, had no issues or reason too.
I cleared codes and ran scan again, 5F only remains tripped, my suspicion it is from a faulty activation code in updating MMI and NAV bacj the end of last year, anyone have ideas or experience on this?
As for 01, I will have to monitor it closely to make sure that it doesn't become a bigger issue. Could this be caused from the same?
I appreciate any advice or thoughts!
Saturday,13,April,2019,14:11:10:45450
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 18.9.0.2 (x64) HEX-V2 CB: 0.4437.4
Data version: 20180927 DS296.0
Ross-Tech: Home
VIN: WA1DGAFE6FD008XXX License Plate:
Mileage: 104970km-65225mi Repair Order:
Chassis Type: FE-AU56 (4F0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 28 34 36 3C 42 46 47 4C 4F
52 55 56 5F 62 69 6C 6D 6F 72
VIN: WA1DGAFE6FD008XXX Mileage: 104970km-65225miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
28-HVAC, Rear -- Status: Malfunction 0010
34-Level Control -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: OK 0000
3C-Lane Change -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
4C-Tire Pressure II -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
69-Trailer -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
6F-Centr. Conv. II -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (CTW) Labels: None
Part No SW: 4L0 910 551 Q HW: 4L0 907 551 A
Component: 3.0l V6 TFSI 0030
Revision: --H08--- Serial number:
Coding: 0121000A290F0928
Shop #: WSC 31414 790 00001
VCID: 3635DBE4644C6517749-8062
1 Fault Found:
001110 - EVAP System
P0456 - 000 - Very Small Leak Detected - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100001
Fault Priority: 4
Fault Frequency: 2
Reset counter: 255
Mileage: 104705 km
Time Indication: 0
Date: 2019.04.11
Time: 06:32:01
Freeze Frame:
Lambda: -8.0 %
Temperature: 25.5°C
Time: 3.20 s
Time: 4.70 s
Time: 128.0 s
Temperature: 18.0°C
Readiness: 0000 0000
Address 02: Auto Trans (J217) Labels:| 0C8-927-750.clb
Part No SW: 0C8 927 750 Q HW: 0C8 927 750 Q
Component: AL1000 AISIN 002 2443
Serial number:
Coding: 001178
Shop #: WSC 30586 001 104857
ASAM Dataset: EV_TCMAL991031 002112
ROD: EV_TCMAL991031_002.rod
VCID: 3A2DCFD45CD48177901-806E
No fault code found.
Address 03: ABS Brakes Labels:. 4L0-910-517-V2.clb
Part No SW: 4L0 910 517 M HW: 4L0 614 517 L
Component: ESP ALLRAD MK25E1 0020
Revision: 00H02001
Coding: 0103505
VCID: 3431E1EC723077074AD-8060
Address 05: Acc/Start Auth. Labels:. 4F0-910-852.clb
Part No SW: 4F0 910 852 B HW: 4F0 905 852 H
Component: FBSAUDIC6 ELV H08 0210
Revision: 00H08000 Serial number: 10603902162043
Coding: 0000135
Shop #: WSC 30586 001 1048576
VCID: 25170CA8C9EA1E8FCD3-8070
Subsystem 1 - Part No: 4F0 910 132 L
Component: FBSAUDIC6 EZS H04 0020
Subsystem 2 - Part No: 4F0 910 335 B
Component: FBSAUDIC6 KSG H03 0020
Subsystem 3 - Part No: 4F0 910 220 G
Component: FBSAUDIC6 IDG H01 0053
Address 08: Auto HVAC (J255) Labels: None
Part No SW: 4L0 910 043 D HW: 4L0 820 043 AQ
Component: KLIMA 4 ZONEN H15 0070
Revision: 00---031 Serial number: 00000000447079
Coding: 001CC026
VCID: 25170CA8C5EA1E8FCD3-8070
Subsystem 1 - Part No SW: 8K0 959 772 F HW: 8K0 959 772
Component: SLR-B8 H06 0007
Serial number: 0115208822
Coding: 070000
Subsystem 2 - Part No SW: 8K0 959 772 F HW: 8K0 959 772
Serial number: 0115208818
Coding: 070000
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 AG HW: 4F0 907 279 C
Component: ILM Fahrer H31 0400
Revision: 00000000 Serial number: 4F0907279
Coding: 0133123
VCID: 6E8533845C9C1DD77C9-803A
Subsystem 1 - Part No: 4L1 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AU716 H18 0110
Coding: 00064792
Shop #: WSC 31414
Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH04 0003
Coding: 00150059
Shop #: WSC 31414
Address 10: Park/Steer Assist (J446) Labels:| 4L0-919-475-7X2.clb
Part No SW: 4L0 919 475 A HW: 4H0 919 475 C
Component: PARKHILFE 8K H07 0011
Revision: 11001001 Serial number: 55961425401612
Coding: 29011F
ASAM Dataset: EV_EPHVA18AU7160000 001001
ROD: EV_EPHVA18AU7160000.rod
VCID: 3431E1EC7EB077074AD-8060
Address 15: Airbags Labels: 4L0-910-655.lbl
Part No SW: 4L0 910 655 A HW: 4L0 959 655 B
Component: 73 AIRBAG AUDI8RH45 0230
Revision: 09H45000 Serial number: 0038QD90ASU+
Coding: 0014131
VCID: 2B03FA90AF0E28FF1B7-807E
Subsystem 1 - Part No: 4L0 959 339 C
Component: BF-Gewichtsens. H05 0040
Subsystem 2 - Serial number: 6332QSME79421A4EQ
Subsystem 3 - Serial number: 6342QSME1F431D4CT
Subsystem 4 - Serial number: 6352QSME43445458E
Subsystem 5 - Serial number: 6362QSME3D44327ES
Subsystem 6 - Serial number: 63734SME71424B54$
Subsystem 7 - Serial number: 63834SME0D454E605
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 B HW: 4F0 953 549 E
Component: J0527 0830
Revision: 00H09000 Serial number: 90026142050193
Coding: 0012142
VCID: 2809059CBEF803E7F65-807C
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 H03 0040
Address 17: Instruments (J285) Labels:. 4L0-920-xxx-17.clb
Part No SW: 4L0 920 985 S HW: 4L0 920 985 S
Component: KOMBIINSTR. H35 0332
Revision: 00000000 Serial number: X2R52NJ9F
Coding: 8BDE63040901CF05020205
VCID: 44D1B12C2E90C787FAD-8010
Address 19: CAN Gateway (J533) Labels:. 4F0-907-468.clb
Part No SW: 4F0 907 468 S HW: 4F0 907 468 G
Component: GW-BEM 5CAN-M H06 0058
Revision: MB800038 Serial number: 3800M1490204F4
Coding: 00C303
VCID: 3FDBBEC04776A45FA7F-806A
Subsystem 1 - Part No SW: 8K0 915 181 D HW: 8K0 915 181 D
Component: J367-BDM H07 0125
Serial number: 41250510334121764484
Address 28: HVAC, Rear Labels: None
Part No SW: 4L0 910 158 HW: 4L0 919 158 AE
Component: KLIMABETAETIGUNGH06 0060
Revision: 00---011 Serial number: 00000030351854
Coding: 0000006
VCID: 6889459C7E78C3E7365-803C
2 Faults Found:
00003 - Control Module
003 - Mechanical Failure - Intermittent
Freeze Frame:
Fault Status: 00100011
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 90393 km
Time Indication: 0
Date: 2018.10.25
Time: 11:41:23
01320 - Control Module for Climatronic (J255)
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 179
Mileage: 101604 km
Time Indication: 0
Date: 2019.02.08
Time: 11:05:51
Freeze Frame:
ON
Address 34: Level Control Labels: 4L0-910-553.lbl
Part No SW: 4L0 910 553 J HW: 4L0 907 553 E
Component: LUFTFDR.-CDC H04 7860
Revision: --H04001 Serial number: 15.1528-0143.2
Coding: 0015520
Shop #: WSC 29409 001 1048576
VCID: 313FE8F88D22422F21B-8064
1 Fault Found:
01577 - Turn-Off due to Over-Temp
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 6
Fault Frequency: 2
Reset counter: 183
Mileage: 104548 km
Time Indication: 0
Date: 2019.04.08
Time: 08:46:39
Freeze Frame:
Error Code: 68
Address 36: Seat Mem. Drvr (J136) Labels: None
Part No SW: 4F0 959 760 D HW: 4F0 959 760 D
Component: MEM-FS H08 0065
Revision: AA000000 Serial number: 00000114006321
Coding: 00581B00000011110000
VCID: 323DE7F484247937581-8066
Address 3C: Lane Change Labels: None
Part No SW: 4L0 910 566 C HW: 4L0 907 566 B
Component: J0769_SWA_MasterH03 0050
Revision: 00H03000 Serial number: 6PZ 009 014-10
Coding: 0010001
VCID: 2E05F3849C1C5DD73C9-807A
Subsystem 1 - Part No: 4L0 910 568 C
Component: J0770_SWA_Slave_H03 0050
Subsystem 2 - Serial number: 6PZ 009 014-30
Subsystem 3 - Serial number: 5F28.08.1400H03000AMS14277ÿ
Subsystem 4 - Serial number: S14277ÿ
Address 42: Door Elect, Driver (J386) Labels:. 4F0-959-793.clb
Part No SW: 4F0 959 793 T HW: 8K0 959 793 M
Component: TSG FA H12 0362
Revision: Serial number: 0000118410359
Coding: 011F57205E40440004
VCID: 48C9A51C12B8E3E7165-801C
Address 46: Central Conv. Labels:. 4L0-910-289.lbl
Part No SW: 4L0 910 289 K HW: 4L0 907 289 K
Component: Komfortgeraet H12 0130
Revision: 0130 --- Serial number: 82007937900000
Coding: 3570077
VCID: 3829D5DC6E589367665-806C
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H05 1501
Address 47: Sound System (J525) Labels: None
Part No SW: 4L0 035 223 J HW: 4L0 035 223 G
Component: BOSE G3 Q7 H04 0160
Revision: CH004001 Serial number: 00000000060077
Coding: 030000
VCID: 290F0098A9F23AEFE9B-807C
Address 4C: Tire Pressure II Labels: 4F0-910-274.clb
Part No SW: 4F0 910 274 B HW: 4F0 907 274
Component: J793 RKA+ H04 0110
Revision: 00000519 Serial number: 00005191069910
Coding: 0694221
VCID: 231312B0C7DEE0BFA37-8076
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280 D
Component: ILM Beifahrer H16 0100
Revision: Serial number: 00000000196405
Coding: 0012001
VCID: 5EE56344AC3C8D57CC9-800A
Address 52: Door Elect, Pass. (J387) Labels:. 4F0-959-792.clb
Part No SW: 4F0 959 792 T HW: 8K0 959 792 M
Component: TSG BF H12 0362
Revision: Serial number: 0000118095476
VCID: 47CBA6201FA6EC9F1FF-8012
Address 55: Headlight Range Labels: 4F0-910-357.lbl
Part No SW: 4L0 910 357 B HW: 4L0 907 357 B
Component: AFS 1 H01 0010
Revision: 00000001 Serial number:
Coding: 0000032
Subsystem 1 - Part No: 7L6 941 329 A
Component: AFS-Modul links H07 0004
Subsystem 2 - Part No: 7L6 941 329 A
Component: AFS-Modul rechtsH07 0004
Address 56: Radio (R) Labels: Redir Fail!
Part No SW: 4G0 035 082 H HW: 4G0 035 082
Component: Radio U SIRIU H60 0138
Revision: AB001007 Serial number: 156I.0E8063162
Coding: 020007010000000000
Address 5F: Information Electr. (J794) Labels: None
Part No SW: 4L2 035 746 H HW: 4L2 035 746 D
Component: H-BNT-NA H41 1040
Revision: -------- Serial number: 224IU0E7551041
Coding: 180200060104F1FF5300334D6D632003140000000100000000
VCID: 3333E2F07B3E703F537-8066
Subsystem 1 - Part No: 8R0 060 884 EN
Component: NAR 2017/2018 1602
Subsystem 2 - Part No SW: 8R0 919 604 A HW: 8R0 919 604 A
Component: DU7 High H42 0104
Serial number: A130IY0E3128854
Subsystem 3 - Part No SW: 4L0 919 614 C HW: 4L0 919 614 C
Component: E0380 Bedient H01 0060
Serial number: 00000002205827
Subsystem 4 - Part No: 8R0 060 961 G
Component: CD-Database 5950
4 Faults Found:
03276 - Please Check Software Version Management
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 167
Mileage: 94744 km
Time Indication: 0
Date: 2018.12.16
Time: 12:31:46
Freeze Frame:
Text: DUA130,Front,M,0,0,6
03157 - Functionality limited due to Communications Disruption
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 175
Mileage: 104438 km
Time Indication: 0
Date: 2019.04.06
Time: 10:56:17
Freeze Frame:
Bin. Bits: 00000000 00000010
Bin. Bits: 00000000 00000000
03623 - Invalid Secruity/Release Code
000 - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 174
Mileage: 94899 km
Time Indication: 0
Date: 2018.12.18
Time: 16:51:50
Freeze Frame:
Hex Value: 0x0004
Hex Value: 0x000B
Count: 6
03677 - Missing Secruity/Release Code
000 - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 174
Mileage: 94899 km
Time Indication: 0
Date: 2018.12.18
Time: 16:49:18
Freeze Frame:
Voltage: 14.60 V
Address 62: Door, Rear Left (J388) Labels:. 4F0-959-795.clb
Part No SW: 4F0 959 795 P HW: 4F0 959 795 P
Component: TSG HL H11 0362
Revision: Serial number: 0000117954997
Coding: 010E57204040230004
VCID: 46D5AB2418ACF597E49-8012
Address 69: Trailer (J345) Labels:. 4E0-907-383.clb
Part No SW: 4E0 907 383 J HW: 4E0 907 383 J
Component: Anhaenger H09 0100
Revision: 2A001001 Serial number: 00008200812238
Coding: 0200000000000000
VCID: 313FE8F88122422F21B-8064
Address 6C: Back-up Cam. (J928) Labels:* None
Part No SW: 4L0 907 428 HW: 7P6 907 441 D
Component: TopView H05 0293
Revision: 11001001 Serial number: 82330JF0171124
Coding: 020C000001000100010102000000
ASAM Dataset: EV_CamSysteCorneViewAUDI 004005
ROD: EV_CamSysteCorneViewAUDI.rod
VCID: 6E853384501C1DD77C9-803A
Address 6D: Trunk Elect. Labels: None
Part No SW: 4L0 910 945 HW: 4L0 827 851 F
Component: ValeoHeckdeckel H58 0500
Revision: --H58001 Serial number: E5030000B
Shop #: WSC 98765 666 38354
VCID: 6C81398C6A80EFC752D-8038
Subsystem 1 - Part No: 4L0 910 946
3ó
Subsystem 3 - Serial number: RD12.09.14--H58001002G0094ÿ
Subsystem 4 - Serial number: 2G0094ÿ
Address 6F: Centr. Conv. II Labels:. 4L0-910-290.lbl
Part No SW: 4L0 910 290 A HW: 4L0 907 290 A
Component: ILM HINTEN 2 H08 0080
Revision: AAH08080 Serial number: 0118255819----
Coding: 0003587
VCID: 26150BA4B4EC1597C49-8072
Subsystem 1 - Part No: 4L0 910 591 A
Component: J_245_EE16_SKB10H15 0220
Subsystem 2 - Part No: 4L0 910 591 A
Component: J_394_EE16_SKB10H15 0220
Subsystem 3 - Part No: 4L0 910 591 A
Component: J_392_EE16_SKB10H15 0220
Address 72: Door, Rear Right (J389) Labels:. 4F0-959-795.clb
Component: TSG HR H11 0362
Revision: Serial number: 0000117954996
End----------(Elapsed Time: 02:17, VBatt start/end: 12.1V/12.1V)-----------
Ross-Tech: Home
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 255
Mileage: 104705 km
Time Indication: 0
Date: 2019.04.11
Time: 06:32:01
Freeze Frame:
Lambda: -8.0 %
Temperature: 25.5°C
Time: 3.20 s
Time: 4.70 s
Time: 128.0 s
Temperature: 18.0°C
Serial number:
Coding: 001178
Revision: 00H02001
Coding: 0103505
Coding: 0000135
Coding: 001CC026
Coding: 070000
Coding: 070000
Coding: 0133123
Coding: 00064792
Shop #: WSC 31414
Coding: 00150059
Shop #: WSC 31414
Coding: 29011F
Coding: 0014131
Coding: 0012142
Coding: 00C303
Coding: 0000006
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 90393 km
Time Indication: 0
Date: 2018.10.25
Time: 11:41:23
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 179
Mileage: 101604 km
Time Indication: 0
Date: 2019.02.08
Time: 11:05:51
Freeze Frame:
ON
Coding: 0015520
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 183
Mileage: 104548 km
Time Indication: 0
Date: 2019.04.08
Time: 08:46:39
Freeze Frame:
Error Code: 68
Coding: 0010001
Coding: 3570077
Coding: 030000
Coding: 0694221
Coding: 0012001
Coding: 0000032
4 Faults Found:
000 - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 167
Mileage: 94744 km
Time Indication: 0
Date: 2018.12.16
Time: 12:31:46
Freeze Frame:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 175
Mileage: 104438 km
Time Indication: 0
Date: 2019.04.06
Time: 10:56:17
Freeze Frame:
000 - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 174
Mileage: 94899 km
Time Indication: 0
Date: 2018.12.18
Time: 16:51:50
Freeze Frame:
Hex Value: 0x0004
Hex Value: 0x000B
Count: 6
000 - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 174
Mileage: 94899 km
Time Indication: 0
Date: 2018.12.18
Time: 16:49:18
Freeze Frame:
Voltage: 14.60 V
3ó
Coding: 0003587
Check engine lights or EPC fault lights are always directed to power train faults and not triggered by other sub module faults in your car as these are seen as non detrimental. Your scan showed the date for the engine fault as yesterday and thats when you experienced the engine light so it was the cause. The EVAP has to do with emissions control for the engine, fuel vapour, crankcase gases etc. since the pump detected a leak it will need to be rectified as the leak wont fix itself bud. You will need to check the evap lines and the pump for a split hose etc.hope this helps.
The light actually came on while out and about the morning before, I did not have a chance to run VCDS until dated and then again to view them and interpret them until today.
I would check the lines from the tank forward, or from the motor back? Not familiar with these faults.
Thanks for the info! Gives me a starting point.
have you had the fuel pump recall performed? could be triggered by that.
I don't know, but I will ask at my next service coming quickly, under 1,000. I do know that it is not listed under my CarFax.
After the reset, I have driven around town with no issues, crossing fingers for a fluke, always!
During my travels abroad, renting tiny cars and fitting them into parking spaces they don't even fit into for over a month, first thing back in my saddle and I rail a F*&n curb so hard parking my wife almost ****!
Going to find a refurb for now, but by the next tire change, I'm going to fat and tall tires like yours!
saw it on here a while back for the 3.0 Gas, housing cracks or something and lets air in.. could see that throwing off evap system cuz it can detect a fuel cap not tightened.. search around and you'll find the TSB i'm sure
either way evap is not going to cause any long term issues if its not working, at least not for the car..
hah yeah I looked at those 20's and said to my self, they wont last a winter here w/our potholes.. perfectly designed to be a curb magnet.
Maguila
A4 (B8 Platform) Discussion
04-07-2019 04:29 AM
blackouts4
02-18-2003 07:01 PM
