Anyone have instructions on how to remove shift boot (not shifter)
I while ago I swapped my shifter for a facelift style shifter out of an Audi A4/A5. It hooked right on and worked fine, but the shift boot is the wrong size, anyone know how I can swap the shift boot from my old shifter to this new one? Is there any website who sells just the shift boot for the Q7? Thanks.
Get yourself a used one from ebay or try the local junkyard/recycler or even Aliexpress. GL
Thanks for the info Raj, I think I'm going to go that route, or somehow swap the bottom clip with the staples. It's not that annoying, I just would like it to look flush with the rest of the interior.
You should be able to unclip the existing (original) boot from the actual **** and fit it to the new one. Thats what I did with my C6 A6 when I swapped to the C7 ****.
Getting the original boot off is relatively easy - you just have to remove the black ring that the boot end is tucked into on the bottom go the ****, then reverse the process for fitting to the new one.
Ive didn't have to buy a new gaiter/boot.
slimj
10-15-2005 11:23 AM
