audi q 7 gearbox oil
hi looking to change my gearbox oil on a 07 q7 is it a big job also any tips would be welcome .Also diff oils and haldex oils to change any recommendations please? cheers nick
Not hard Q7 has one of the easy way to change the front and rear Diffs.
The two procedures show the top bolt, the drain bolt is the same and it is on the bottom of the Diff.
Undo the top bolt 1st just incase it cannot be remove. This is because it you removed the bottom one 1st then you have no way to fill the Diff.
Need a pump to pump the fluid up wards.
The front top Diff was a little hard, had to used two wrenches to make one long one to undo the bolt.
Q7 - Axle Oil Level In Front Final.pdf
Q7 Rear Final Drive Axle Oil Lev.pdf
One minor point, if you think the Q7 has a haldex diff I would hesitate to recommend that you attempt changing the transmission fluid.
Do some more research first because you need at least some basic knowledge about the car you are working on and whilst draining the trans fluid is easy, re-filling requires careful monitoring of temperatures as it is filled to reach the correct level.
No, as far as I am aware all the TDI and 4.2 use the Aisin 09d trans whereas the 3.6 uses a ZF so not even the fluid will be the same let alone the filter or gaskets etc....
The re-fill procedure will be different as well.
Thanks Edd for pointing me in the right direction. I wanted to share what I found to help contribute as I feel this info was difficult to find. The transmission is 0AT which I found on Amsoil's website and I cross referenced that to ZF part # ZF6HP19
Amsoil's link to the 2008 Q7 3.6 includes other great info
2008 AUDI Q7 3.6L 6-cyl Engine Code BHK - AMSOIL Online Product Application Guide
I found a ZF Service Information sheet that will help with a DIY
http://www.zf.com/global/media/medie...hselkit_EN.pdf
And finally I found this Service Training Guide published by Audi
http://vwts.ru/pps/pps_993603_audi_q...ission_eng.pdf
I have yet to review all this in its entirety but wanted to post it before I lost it. Hopes this helps someone looking to tackle this.
Here is my list I bought. All ZF product.
Qty SKU Product Name Unit Price
1 0AT325429-MFG103 Transmission Filter. $56.89
1 0AT321371-MFG103 Transmission Pan Gasket $48.16
7 G055162A2-MFG103 ATF $22.99
SubTotal: $265.98
SubTotal: $265.98
popdemonic
Audi Original "S" Cars
01-18-2009 10:06 PM
Blue2
02-24-2008 06:06 PM
SFexBOY
11-12-2006 10:40 AM
mike-lur
12-13-2001 10:16 AM
