Can I add water to my Q7 Battery?
The battery on our 2013 Q7 Prestige is crapping out, and we had to get a jump today. The alternator is bumping up the voltage to about 13.6V, so I don't think that is the problem. I will pull the seat back and look at the battery soon, and assuming it is OEM does anyone know if it is sealed or can I add distilled water?
Thanks in advance.
Thanks in advance.
Word of advice, if your battery dies anywhere but home; you're going to have to apply power to the jump points to be able to move the seat for an emergency change. So save yourself the heartache and just change it now.
However you answer your question, you're probably OEM, which is lead acid. So you should be able to top it up.
Correct, either a battery tender/ charger or a jump pack. The Touareg and Cayenne's are the same way.. Here's a quick video from a Touareg, the Q7's only have a few terrible videos and the good one is from the UK with the steering wheel on the other side (battery change would be a breeze in that case).
bingS4
08-02-2008 05:04 PM
SamXXXXXXXX
11
07-15-2008 08:11 AM
Arcteryx::Stock Rods
10-17-2004 11:55 AM
LCP
08-11-2002 10:31 AM
